Old 08-27-2002, 11:48 AM   #1
palallin
Camper Wiring
What is included with the "Camper Wiring" option? It's listed on my truck, but I see no evidence of additional wiring over and above the normal rear light harness.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
Old 08-27-2002, 12:50 PM   #2
JimKshortstep4x4
Smile
The camper wiring is a separate harness that plugs in between the firewall end of your tailight wiring and the wireing from under the dash. It has a separate red #10 wire that is in the harness but it routes across the saddle and terminates at the connector block on the passenger fender. In addition to the red positive wire there is a white #10 ground wire that is grounded to the outside firewall above the engine. The harness is routed along the frame with separate wire retainers to behind the cab and up into the front part of the truck bed. It is long enough to connect inside the camper but I don't know how that was accomplished.
Jim
Old 08-28-2002, 12:03 AM   #3
palallin
Hmmmm; I don't think there's a trace of any of that left. What, exactly, did it do, anyway? Which frame rail did it travel down, and does anyone have a pic of the connectors?
Does anyone have a harness they'd be willing to part with?
Old 08-28-2002, 06:46 AM   #4
JimKshortstep4x4
Smile
The camper wiring supplied the camper with 12 volt power for lighting, parking light circuit for the parking lights, brake and turnsignal circuit, and backup light circuit. (Every circuit that goes to the tailights, etc. plus the 12 volt circuit and ground). It is a
convenient way to wire in a camper.
If you are unable to get one from the parts board, let me know and I will check my local yard.
Jim
Old 08-28-2002, 11:03 AM   #5
jku72
i have this camper wiring as well, it consists of a plug/terminal that can be unpluged between the cab and the bed along the drivers side frame rail. The plug looks just like a trailer wiring plug, the older round 12 pin type. It is designed to plug into a receptacle on the camper shell when one is on, and when empty, the plug goes back to the tail light wiring as any other truck. The only place to see any difference is if you look at the drivers side frame rail, under the front part of the bed.
jku Cornville, Maine
68 C10 burb
42 Willys MB
46 Dodge WF-32 1.5 ton
53 & 56 Olds'
60 Cadillac
22 Dodge Brothers
jku72 is offline   Reply With Quote
Old 08-28-2002, 02:57 PM   #6
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Just an FYI, I got the new catalog from Pickups Northwest and they have the camper wiring harness listed. I don't remember the price and the catalog is at home right now. I haven't ever seen it listed anyplace else before but I did notice it last night while dreaming about all the new toys for my truck.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 08-28-2002, 05:07 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I have one, but it's only 1/2 there. All hacked up and stuff. I think there is some add on on mine too. and a huge cable for ground.
Old 08-28-2002, 05:24 PM   #8
jku72
Yup, that's it, if you now imagine that along the inside of the framerail, plugged into a female receptacle, you know what to look for anyway.
68 C10 burb
42 Willys MB
53 & 56 Olds'
60 Cadillac
22 Dodge Brothers
