Old 02-06-2007, 06:10 PM   #1
Dano69c10
Dano69c10's Avatar
Angry WTF:1970 c10 a no go!
I went out to start my truck this morning to go to work.
The truck started fine, I let it warm up for a couple of minutes.
I put it Drive and stepped on the gas, NO GO!
I put the gear selector in every gear and still no go!
Embarassed as hell, the wife drove me to work in her F@&d!!!
Can anyone tell me where to start investigating?
Thanx in advance
Dano
'69 Fleet
It ain't yours, if you didn't build it!
Dano69c10 is offline   Reply With Quote
Old 02-06-2007, 06:12 PM   #2
1969k10stepside
Re: WTF:1970 c10 a no go!
Transmission?
1969k10stepside is offline   Reply With Quote
Old 02-06-2007, 06:17 PM   #3
Dano69c10
Dano69c10's Avatar
What could it be on the tranny, Torque converter? I also thought that maybe my linkage wasn't shifting the tranny, but I can feel the indents when I move the gear selector.
'69 Fleet
Old 02-06-2007, 06:18 PM   #4
1969k10stepside
It might be the linkages.Has the tranny been rebuilt before to your knowledge?
Old 02-06-2007, 06:30 PM   #5
72chevy327
Id say to my knowledge its the torque converter but only if your sure its full of fluid and its going into gear. if its not that then you have bigger problems.
72chevy327 is offline   Reply With Quote
Old 02-06-2007, 06:43 PM   #6
jimmydean
jimmydean's Avatar
This might be totally random, but I had the filter on my TH350 fall off and it wouldn't allow fluid to flow, so no gear would engage. The trans burned up shortly after that.
I haven't owned an auto truck since.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 02-06-2007, 06:54 PM   #7
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
I had similar problems with the TH350 in the last two cars I drove when it was cold-no go unless they were well warmed. One however, had obvious problems, because it didn't like going into reverse, the other worked well all the time except when the temps dropped. I have a rebuilt TH350 in my truck now and haven't had any problems (is actually the one that slipped in reverse), so I too am curious.
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 02-06-2007, 06:59 PM   #8
cst70rocket
somebody stole your driveshaft hehe
cst70rocket is offline   Reply With Quote
Old 02-06-2007, 07:10 PM   #9
watahyahknow
watahyahknow's Avatar
could be the rear brakes are frosen up , did the rpm dropped when you put it in gear?
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 02-06-2007, 07:11 PM   #10
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
Someone put your rear end on blocks? J/K Definitely sounds like a fluid or converter problem if there's no tranny noise.
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 02-06-2007, 07:13 PM   #11
lilpup69chevy
67-72 parts finder
lilpup69chevy's Avatar
i'd check the ground underneath for a leak first another thing try putting it in neutral and revving it up this will help prime the converter, i had a truck once that until you revved it up in neutral for a minute it wouldn't move at all. transmissions are funny something could be internally broke even, my 88 silverado was fine on the way to work one day then at lunch it wouldn't pull then it slung parts, in your case i'd think it was torque converter problems, wouldn't hurt to check the transmission lines etc, maybe the modulator valve line came loose? but even at that it would still pull just not shift
1969 chevy shortstep 2wd (under construction)
1981 chevy scottsdale lwb 2wd (parts chaser)
2004 pontiac gto (daily driver)
2004 pontiac grand prix gt (the ol ladys car)
1985 chevy short wide
1970 chevy c10 lwb (another parts rig)
1969 gmc lwb (rainy day project)
1968 chevy lwb c10 250 I6 3 spd (soon to be swb)
lilpup69chevy is offline   Reply With Quote
Old 02-06-2007, 07:35 PM   #12
cdowns
cdowns's Avatar
first thing i'd do would be crawl under the truck and see if your linkage is still hooked up to the transmission
Old 02-06-2007, 08:08 PM   #13
VetteVet
Msgt USAF Ret
VetteVet's Avatar
The same thing happened to my boy's car and we pulled the pan off the tranny (Th350) and the s-link had fallen off the linkage to the valve body. I wish I had a picture but I lost it when the hard drive crashed on my computer.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 02-06-2007, 08:20 PM   #14
sick69
sick69's Avatar
I would let it warm up again and check the fluid. if the fluid level is ok the check the govenor. its under one of the covers on the side of the tranny.(I believe the right side cover)its just a shaft with a couple counterweights on it. if the springs or the gear on the govenor are trashed it will have the same symptoms as you've described.
the only reason I suggest it is because I have had two go out on me on two seperate trannies. some of the people I hang around with are ase certified techs(one is a tranny tech for gm) and have told me that the govenor going out is a one in a million. I guess I was just lucky!
Frank
70 chevy lwb c10
454/th400 and a 9" rearend
suicide doors, marker light fuel fill, 4" cowl , mini tub
sick69 is offline   Reply With Quote
Old 02-06-2007, 11:20 PM   #15
Dano69c10
Dano69c10's Avatar
Was dark when I got home.
I know the tranny was leaking fluid so I'll check that first at daybreak.
I had also thought someone stole the driveshaft, (they might have needed it), but it was still there.
The RPMs did not drop when I shifted into gear.
When I put the truck in neutral I could push it, so brakes aren't locked up. I have a feeling the the tranny is stuck in neutral, because no matter where the shifter is I can push the truck forward and backward.
Thanx, will keep you all posted.
Dano
'69 Fleet
