08-27-2002, 03:01 PM | #1 |
aka Crusher, Crushergmc
Upper A arm diagram help.
I need a pic/scan of the upper A arm assembly drawing. The one I'm rebuilding has a bunch of miscellaneous bolts and washers. I noticed that a couple washers are not typical and I want to make sure I have them in the right place. If no pics are available, can someone take me step by step through the process of bolting the assembly to the crossmember. Thanks
"KEEP IT DOWN!" 70 Jimmy 454 2wd 56 GMC Big Window "It's funny till someone gets hurt, then it's freakin' hilarious" |
08-27-2002, 07:28 PM | #2 |
Here is a pic with the A arm removed.
69-C10 LWB 71- fleetside shortbed It's a shame stupidity isn't painful Never play leapfrog with a unicorn |
08-27-2002, 07:33 PM | #3 |
let me try this again
08-27-2002, 11:24 PM | #4 |
Ah hah, that's the funky washer I was talking about, except mine aren't square, but same idea. That kinda threw me off looking at the LMC cat. I need to get more of these. Thanks!
08-27-2002, 11:35 PM | #5 |
The "washers" are shims to adjust your upper a arms for alignment, If you changed the placement then you will need a alignment possibly.
08-27-2002, 11:35 PM | #6 |
Here is another one all together...
