Old 02-07-2007, 06:40 PM   #1
st1x10
st1x10's Avatar
headers with bags plz!!
I am looking for a set of headers to replace the rusted ones on there now. I am looking at the Hedman Elites, but am wondering if I should get the shorty's since the truck in the future will be bagged.
1970 Chevy C10 "Under Construction"
2002 Chevy S10 V6
st1x10 is offline   Reply With Quote
Old 02-07-2007, 06:53 PM   #2
jimmydean
jimmydean's Avatar
Re: headers with bags plz!!
Depends on how low you expect to go. Some full length headers have plenty of room if you're not laid out. Mine are only about an inch bellow the frame rail, but my frame is about 8" off the ground when dumped, so it's not an issue.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 02-07-2007, 07:16 PM   #3
st1x10
st1x10's Avatar
Well currently the headers are completely below the frame. I am planning to go pretty low. Bags and spindles up front. What kinda headers are u using?
2002 Chevy S10 V6
Old 02-08-2007, 12:22 AM   #4
gringoloco
A guy with a truck
gringoloco's Avatar
You can't go wrong with Hedman Elites. 3/8" flange, 14ga tubing, ball flange collectors, nice coating. If you're bagging it, longtubes will be too low.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 02-08-2007, 12:43 AM   #5
jlaird
jlaird's Avatar
search for headers in title only in suspension forum:
http://67-72chevytrucks.com/vboard/s...earchid=370978
jlaird is offline   Reply With Quote
Old 02-08-2007, 04:47 AM   #6
Kevin45
Kevin45's Avatar
Edelbrock shorties let's you use your factory exhaust. So I imagine just about all shorties are the same. They stick out just a little further than the stock exhaust manifol maybe by an inch or so.
Kevin
'93 Silverado Reg. Cab Shortbox
.060 over 350 Quick and fun!!!
Kevin45 is offline   Reply With Quote
Old 02-08-2007, 11:25 AM   #7
bagged69c10
soon to be bagged64sub
bagged69c10's Avatar
11108FLT is the part number for the ones that everyone I know uses. They are shortys from Flowtech originally for an older camaro but work great on our trucks.
1969 c-10, bagged, Zd, 20" Boyds SOLD!
1964 Suburban COMING SOON Build threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=304726
1965 c-10 long bed
1993 Sierra x-cab
1999 tahoe-4/5 on 22s
2005 Chevy work truck
bagged69c10 is offline   Reply With Quote
Old 02-08-2007, 02:36 PM   #8
st1x10
st1x10's Avatar
Aight. I found these
Anybody using them?
2002 Chevy S10 V6
Old 02-08-2007, 05:59 PM   #9
bagged69c10
What?
1965 c-10 long bed
1993 Sierra x-cab
Old 02-08-2007, 07:39 PM   #10
jlaird
jlaird's Avatar
Here's a list of shortys/blockhuggers:
Flowtech
11108FLT (painted)
31108FLT (ceramic coated)
5/16 flange, 18ga, 1.5” prim.
$239.95
Dynomax
WLK-86118 (ceramic coated)
$285.95
Hedman Elite
HED-69640 (painted)
HED-69648 (ceramic coated)
3/8 flange, 14ga, 1.5” prim.
$294.00
Sanderson
CC3 (available in both painted or coated)
Info unknown
$375.00
Hooker
HOK-2466HKR (painted)
HOK-2466-1HKR (coated)
5/16 flange, 16ga, 15/8” prim.
$369.95
All prices are for coated. What do you think the best deal is?
Old 02-08-2007, 08:28 PM   #11
Inthuwind
Straight jacket required
Inthuwind's Avatar
For Big Block and bagged, I heard Sanderson C5 full length will clear very well.
1968 C10 Short Stepper
350/350 A/C P/S P/B Front disc
3/5 static/ 12bolt rear 3:73
1979 Pontiac Trans Am
10th Anniversary/455/4spd
2011 H-D Street Glide - CAMMED n lowered
Dad always said,"Son, if you can't be good...be good at it."
Inthuwind is offline   Reply With Quote
Old 02-08-2007, 10:32 PM   #12
Shane
Shane's Avatar
Dynomax 3/4 length for chevelle/malibu here ....
Shane is offline   Reply With Quote
Old 02-09-2007, 12:47 AM   #13
gringoloco
A guy with a truck
gringoloco's Avatar
Chevelle headers were NOT a bolt-in for me. Big time intereference with the motor mounts. Swapping to 73-87 motor mounts cures this problem, but does nothing for the 1/4-3/8" frame 'clearancing' needed. Your results may vary. If I had it to do again, I'd probably spring for the Hedman shorties that fit perfectly with no issues, even considering the screamin' deal I got on the Chevelle style. <--My $.02.
-Chris
-Chris
Old 02-09-2007, 12:39 PM   #14
b&a72
Active Member
b&a72's Avatar
-Chris
Where can I get the Hedman's? And are they the Elite's?
b&a72 is offline   Reply With Quote
Old 02-09-2007, 02:42 PM   #15
st1x10
st1x10's Avatar
Thanks for all the help guys, I think I am going to go with the Hedman coated headers.
2002 Chevy S10 V6
Old 02-09-2007, 03:35 PM   #16
gringoloco
A guy with a truck
gringoloco's Avatar
Summitracing.com. They are Elites.
-Chris
Old 02-09-2007, 06:10 PM   #17
Shane
Shane's Avatar
Sorry to hear that gringo ... I know a few people that have used the DynoMax Chevelle\Malibu headers that had no problems.
Were your's DynoMax brand or an another? I ask only because I am curious if there is a difference between manufacturers.
Old 02-09-2007, 07:25 PM   #18
jlaird
jlaird's Avatar
good choice. I think those are the ones I'm going to go with as well.
Old 02-10-2007, 01:32 AM   #19
gringoloco
A guy with a truck
gringoloco's Avatar
They were the eBay headers. I got them for way less than what they normally go for, so I'm not real upset about doing some small mods to make 'em work. They are surprisingly quality pieces though; thick flanges, heavy tubing, nice coating. I imagine if I'd been using them on a Chevelle, I would have been completely satisfied.
-Chris
-Chris
