Old 08-27-2002, 03:35 PM   #1
dion
72 Cheyenne
dion's Avatar
350 Cam question
What size Cams are you guys running with what engines? I need to get a better Cam.
Burnout
Idle
1972Cheyenne
1966/67Stouts
dion is offline   Reply With Quote
Old 08-27-2002, 06:21 PM   #2
bigjimzlll
bigjimzlll's Avatar
268H in a 355 with 10-1 c/r and fuellie heads...works real good 5300 redline..thats the most I can get out of the heads
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 08-27-2002, 06:50 PM   #3
Sinister
Between Trucks...
Sinister's Avatar
hey bigjimzlll, what kinda cam timing are you running? are you a couple degrees retarded or what?
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 08-27-2002, 08:00 PM   #4
Tracy Focht
Tracy Focht's Avatar
Re: 350 Cam question
Depends, what do you plan for this...what mods have you done, or going to do? That will determine what cam will work best. Post and we can help out...
Tracy Focht is offline   Reply With Quote
Old 08-27-2002, 09:32 PM   #5
dion
72 Cheyenne
dion's Avatar
9.1 Compression, roller timing, Jr. Victor Intake, 650 Q Jet, 2200 Stall, what else do you need?
Burnout
Idle
1972Cheyenne
1966/67Stouts
Old 08-28-2002, 09:25 AM   #6
Tracy Focht
Either Comp 268H High Energy cam or the Comp XE268, Xtreme cam will do awesome..
