Old 02-11-2007, 06:07 PM   #1
wakeboarddrumma
wakeboarddrumma's Avatar
Replacing Master Cylinder (Brakes)
My brakes have been out for a while. So I haven't driven the truck. We called the shop we always take it to, and they said it's probably going to be the Master Cylinder. So we said ok, and then they were going to have to tow it, so we decided we'd replace it ourselves, as it couldn't be that hard.
Anyways, we went to Advanced and got a rebuilt one yesterday, and I was just wondering how hard of a job it will be? How long am i looking at for the replacement?
wakeboarddrumma is offline   Reply With Quote
Old 02-11-2007, 07:10 PM   #2
krue
Designated A-hole!
krue's Avatar
Re: Replacing Master Cylinder (Brakes)
Just follow the instructions for bench bleeding, then bleed all your brakes carefully and you should be done with an hour or maybe two or work in it.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 02-11-2007, 10:19 PM   #3
GMCBubba
GMCBubba's Avatar
yeah, i just finished mine a couple weeks ago. and if i can do it, then truly anyone can.
1969 GMC 3/4 ton, 307, 4-speed NP435GL, DANA 60, 4.10, HD rear leafs, manual everything, leaking oil and water. Now rocking 383, NV4500, power steering, power brakes. Finally undergoing restoration.
GMCBubba is offline   Reply With Quote
Old 02-11-2007, 10:37 PM   #4
GMCBubba
GMCBubba's Avatar
oh, and if you're going to the effort to bleed your brake system, you might think about replacing your old brake hoses with new ones. mine were pretty bad. granted, i just replaced everything in my brake system except the hard lines.
Old 02-11-2007, 10:40 PM   #5
msgross
msgross's Avatar
buy a big jar of fluid as you will need it to bleed. takes two people as well... Might pick up a 7/16 line wrench if you don't have one.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 02-11-2007, 11:13 PM   #6
krue
Designated A-hole!
krue's Avatar
Get a GOOD line wrench, don't cheap out here, you'll round off the nuts if you don't.
www.daveramsey.com
Old 02-12-2007, 12:44 AM   #7
CMars45000
CMars45000's Avatar
I agree...This is one of the few tools where I called the Snap-On guy..The craftsman ones didn't cut it...they sure have saved a lot of head aches...
Project Family Values Build Thread
Vehicles/Projects:
-1971 C10 SWB Fleetside! Gathering parts now, will begin frame-off resto soon...
Pleasure in the job puts perfection in the work.
-Aristotle
CMars45000 is offline   Reply With Quote
Old 02-12-2007, 07:40 AM   #8
GMCBubba
GMCBubba's Avatar
yes, rounded nuts. been there, done that. there's at least a couple good sides left to all of my nuts. but they're not as pretty as i would like.
Old 02-12-2007, 09:13 PM   #9
wakeboarddrumma
Well my older brother got the cylinder mounted. Said something about taking off the valves at the wheels and how he couldn't do it. This sound familiar? He stopped, and is going to finish up when he figures it out.
Old 02-12-2007, 10:08 PM   #10
msgross
msgross's Avatar
If the wheel cylinders are leaking then they need replaced, maybe the valves on them are bad, you have to open them to bleed the system
The Garage:
Old 02-12-2007, 10:15 PM   #11
krue
Designated A-hole!
krue's Avatar
Here's a tip for those of us with cheap line wrenches. If there is room, clamp a pair of vice grips on the wrench to keep the ends from spreading, I figured that out in the junkyard the other day.
www.daveramsey.com
Old 02-12-2007, 10:54 PM   #12
wakeboarddrumma
Is there a speacial tool for the front valves?
Old 02-12-2007, 11:07 PM   #13
krue
Designated A-hole!
krue's Avatar
If you're talking about the bleeders, just use a boxed end wrench.
www.daveramsey.com
Old 02-12-2007, 11:41 PM   #14
FarmTruk
In Memoriam...
FarmTruk's Avatar
Thanks krue...that IS a good tip. Wish I'd thought of it. I've rounded off several in my past.
'68 C10 SWB 307ci 2BBL
FarmTruk Pics Here
"You know, doing what is right is easy. The problem is knowing what is right."
FarmTruk is offline   Reply With Quote
Old 02-13-2007, 08:05 AM   #15
krue
Designated A-hole!
krue's Avatar
It just struck me the other day in the junkyard. I had a pair of vicegrips in my hand and waalaah (or however you spell it).
www.daveramsey.com
Old 02-13-2007, 08:46 AM   #16
msgross
msgross's Avatar
Here ya go....
http://www.answers.com/topic/voila-1
or
http://www.answers.com/voila
The Garage:
Old 02-13-2007, 12:01 PM   #17
JustLiveIt
JustLiveIt's Avatar
I just replaced my master cylinder and all brake components including lines. There are many sites online that will have good brake bleeding information. www.classicperform.com, CPP's website is a good one.
Make sure you do a good job bleeding the master cylinder before you install it and bleed the brakes. I didn't do a good job and I have a spongy pedal. I need to take it off and try again. I used a Mighty-Vac at first to bleed the brakes but in the end I found it easier and quicker to have a buddy help me do it the old fashioned way.
1968 Chev SWB Fleet with GMC Clip and lots of 71-72 parts!
JustLiveIt is offline   Reply With Quote
Old 02-13-2007, 01:25 PM   #18
65-72 chevytoys
65-72 chevytoys's Avatar
Make sure you bench bleed the MC first. If you dont and try to bleed the lines it will take forever to get all the air out of the MC through the lines.
2004 Chevy Silverado 1500LS SWB 5.3L
2004 Corvette Z16 #770
Wish I had not sold 72 blazer
65-72 chevytoys is offline   Reply With Quote
Old 02-13-2007, 05:50 PM   #19
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
You guy's use line wrenches? My wife confused the guy at Sears when she asked for them.He called them flare nut wrenches and had no idea there was another name or use for them.I hardly ever use a line wrench to bleed brakes.I can almost always get a box end wrench on the bleeders but have started using a socket most of the time.Sure keeps spraying fluid down and usually misses my safety glasses.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
