02-12-2007, 01:32 PM | #1 |
Manifold Paint
is there a paint can spray paint that will hold up on manifolds?? i found that it will cost 150.00 to ceramic coat my ramhorns. not in the po-boy budget!!
1972 C-10 SWB 350CI TURBO 350 TRANNY, TILT, POWER WINDOW & BRAKES, TANK UNDER THE BED W/MARKER LIGHT FILLER. 3.08 GEARS, CLASSIC AIR :hit2: :hit2: 4 WHEEL DISK BRAKES 2000 chevy blazer 1990 nissan pick-up 1984 mazda pick-up (son's project truck) |
02-12-2007, 02:11 PM | #2 |
Still Green but learning
Re: Manifold Paint
I wirebrushed my headers and used Flamethrower ceramic blend paint from Autozone.... its still holding up but its only been 4 months and its not my dd, hope this helps
-- Cory 71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab 07 Suburban LTZ 4x4 2010 Acura TL 98 Mastercraft "FrankenStar" 225 27253 UPS/USPS IIOY....nope never was |
02-12-2007, 02:11 PM | #3 |
Sierra Grande Club
Re: Manifold Paint
I used Dupli-color that is sold at any auto parts store. Good to 1200 deg. it has some ceramic properties too. I did the optional backing process which it says it will be more resistant & more durable.
s/t Forgot to mention I sand blasted with aluminum oxide first.
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. Last edited by Sport/Truck; 02-12-2007 at 02:13 PM. |
02-12-2007, 02:12 PM | #4 |
Re: Manifold Paint
VHT makes a cast iron grey paint made just for manifolds. I used some on my headers and it held up really well. Here are some pics.
02-12-2007, 02:33 PM | #5 | |
Re: Manifold Paint
02-12-2007, 02:35 PM | #6 |
Parts and more parts
Re: Manifold Paint
Check out Eastwood's website for their manifold coating. I have seen the stuff and it works great.
02-12-2007, 02:39 PM | #7 |
Sierra Grande Club
Re: Manifold Paint
It’s listed on the can 400 deg 1.5 hours.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
02-12-2007, 04:43 PM | #8 |
Cantankerous Geezer
Re: Manifold Paint
The VHT is the best. But, you have to get the metal clean for it to stick properly. Very clean.
Fred There is no such thing as too much cam...just not enough engine. |
02-12-2007, 05:14 PM | #9 |
Re: Manifold Paint
Thats the one I used, the "VHT Flame proof"
02-12-2007, 08:03 PM | #10 |
Happy to be here
Re: Manifold Paint
Try Eastwood Stainless Steel paint. It gives them a bead blasted look and you can spray it or brush it on...
02-12-2007, 08:11 PM | #11 |
Re: Manifold Paint
My eastwood manifold coating did not last. I had them sandblasted cleand then painted and withing 3mo rust was back. I would recomment the VHT or duplicolor.
2004 Chevy Silverado 1500LS SWB 5.3L 2004 Corvette Z16 #770 Wish I had not sold 72 blazer |
02-12-2007, 08:15 PM | #12 |
~Rest In Peace~
Re: Manifold Paint
vht flameproof
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
02-13-2007, 10:06 AM | #13 |
Active Member
Re: Manifold Paint
I used the POR 15 manifold paint. Sand blasted them first, then brushed on 2 coats. Now my truck is not a daily driver, but these have been painted about 1 1/2 years, and been through several heat cycles. I am pleased so far.
