Junior Member
What proportioning valve do I use????
Well I am doing the 88 6lug brake conversion withe the c20 control arm and so on.
I got a new master cylinder for a 71-72 with disks but my auto parts dosen't show a listing for the propotioning valve. Does any one have a part number or have any info that could help. Last edited by bigo181979; 02-12-2007 at 04:36 PM. |
its all about the +6 inches
Re: What proportioning valve do I use????
I would run the factory drum/drum block to maintian the dash warning light, and then an adjustable prop valve (aftermarket) for the reat. This way you can fine tune it instead of guessing, or going off of some one elses's *good enough* homework. Simply installing taller tires in the rear can throw the proportioning way off.
![]() ![]() Join Date: Jul 2002
Here is one source
http://www.inlinetube.com/Prop%20Valves/VCT103.htm Other than that quickly, the only place (new-stock) I have ever found a proportioning valve was the dealer. Using an aftermarket adjustable is probably the best bet as Andy mentioned.
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 02-12-2007 at 04:56 PM. |
Junior Member
anyone else????
#5 | |
Son Of Gravel Man
gmcpauls.com
http://www.gmcpauls.com/Brakes&Steering.htm Brake Proportioning Valve W/Bracket & Lines Each 1286368 New replacement brake proportioning valve with correct mounting bracket to mount the valve to master cylinder, proportioning valve to master cylinder pre-bent brake lines. All needed installation hardware is included. Specify in cart style needed. Disc/Drum, or 4 wheel disc brakes. $89.95 Did you lok at this one? I used the disk/drum one when I did my drop/front disk conversion.
Daily driven 70 C10 longbed Its a work in progress ![]() Quote:
#6 | |
Junior Member
Thanks thats what I was looking for. |
#7 | |
Son Of Gravel Man
Glad i could help.
