02-12-2007, 04:52 PM | #1 |
suspension help
im rebuilding a 1972 chevy c10 and would like help with suspension upgrades...any suggestions?
02-12-2007, 04:55 PM | #2 |
Re: suspension help
What are you trying to build, low rider, air ride, lifted???
Happiness is towing your "new" truck home. 1972 C-10 1982 GMC (parts truck??) 1969 c10 parts truck 1969 C-10 ( my sons) 1992 Silverado 4X4 (now the boys truck)(now mine again) 2002 Tarus (my wife loves that car) |
02-12-2007, 04:58 PM | #3 |
Re: suspension help
i want a lowered truck...not bagged, i was thing of coil overs in the rear and bigger swaybars in both front and rear...im lost suspension wise
02-12-2007, 05:17 PM | #4 |
Re: suspension help
If you ever plan on hauling anything in the back, coilovers will kill that idea real fast. If you want to make your truck handle like a car, then coilovers are a sweet upgrade.
If you don't want to lower it too much, then spindles and a 4" spring will give you a good stance and keep a majority of you ride quality. Rear blocks are also an option for a little more drop without loosing ride.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
02-13-2007, 02:31 PM | #5 |
Re: suspension help
thanks for the help...will the gage cluster from a 67 wire up to a 72?
02-13-2007, 03:00 PM | #6 |
Re: suspension help
As long as both clusters have the same guages
