Old 02-13-2007, 01:25 AM   #1
skokie
skokie's Avatar
Harmonic Balancer
The rubber in my balancer is looking pretty bad and I am going to replace it. I was looking at balancer and I am seeing some that have the key way slot at 10 degrees. http://store.summitracing.com/partde...art=SUM-161350
I was looking at mine and it looks like its right at 0-2 degrees.
Which one should I get or does it matter?
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 02-13-2007, 01:31 AM   #2
cooters
Re: Harmonic Balancer
depending on the timing cover you have, you need the right balancer. Your mark is in line with the keyway on the crank, get the same one as that unless you change timing covers
cooters is offline   Reply With Quote
Old 02-13-2007, 01:35 AM   #3
skokie
skokie's Avatar
Lets say I go with the one at summit. Which timing tab would I need to get?
68 build thread
Old 02-13-2007, 09:24 AM   #4
cooters
looks like the rght one to me, just confirm diamater before ordering
Old 02-13-2007, 09:36 AM   #5
clay68c10
clay68c10's Avatar
Since you have everthing accessable, double check TDC #1. Then you know everthing is dead-nuts on when you get it back together. Those timing tabs aren't always right on.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 02-13-2007, 10:50 AM   #6
skokie
skokie's Avatar
Whats the best way to do this?
68 build thread
Old 02-13-2007, 12:57 PM   #7
WorkinLonghorn
WorkinLonghorn's Avatar
Get a "piston stop" i think they're called.You screw it into the #1 spark plug hole and then carefully by hand turn the engine until #1 piston just hits the stop.Make a mark. Then turn the engine back the other way until #1 piston just hits the stop.Make another mark.The point exactly in between these two marks is true TDC.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent.
WorkinLonghorn is offline   Reply With Quote
