Old 02-13-2007, 07:54 PM   #1
unreconstructed1
nec absolutum
unreconstructed1's Avatar
OK heres another dumb question
ok everybody, I want to convert the E-brake handle on my 67 GMC from the pull handle type to the pedal type ( yall do know what im talkin about here, right?) all I should have to do is to switch out the assemblies and readjust the cable right? if not can you tell me how to do it?
unreconstructed1 is offline   Reply With Quote
Old 02-13-2007, 07:58 PM   #2
neonlarry
neonlarry's Avatar
Re: OK heres another dumb question
A little more complicated than that. Look here:
http://www.classicheartbeat.com/panel_5.htm
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 02-13-2007, 08:13 PM   #3
hp1967c10
hp1967c10's Avatar
I am going to do the same thing but I would think there would be some way of fabricating the foot pedal brake (make a new bracket or something) rather than cutting out the firewall. I have a full body off going and working on my cab as we speak so I will look this over carefully. Thanks for the heads up!
Happy Truckin
HP
hp1967c10 is offline   Reply With Quote
Old 02-13-2007, 08:49 PM   #4
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
OK I will follow the dumb questions route as well,,,,
Do we really need a parking brake?
What do you folks think?
I have been kicking around the idea of getting rid of my ebrake pedal or changing over to the floor mounted style that was used in the larger 2 ton style trucks. I thought maybe mount it between the door and the seat, next to my floor shifter or maybe behind the bench seat.
Just kicking around some ideas.
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 02-13-2007, 09:02 PM   #5
boogie67
boogie67's Avatar
When ihad my last truck inspected he check the brake to see if it would hold.
77 swb starting all over again.
boogie67 is offline   Reply With Quote
Old 02-13-2007, 09:06 PM   #6
FarmTruk
In Memoriam...
FarmTruk's Avatar
You'll definately want that E-brake if you ever have a hydraulic failure with the normal brake system.
'68 C10 SWB 307ci 2BBL
FarmTruk Pics Here
"You know, doing what is right is easy. The problem is knowing what is right."
FarmTruk is offline   Reply With Quote
