02-13-2007, 09:11 PM | #1 |
anybody ever seen a gas tank delete???
this is a 1970 1 ton dually i got a while back and was wondering if anyone has ever seen one i assume its factory because on the spid it has a option for cylindric fuel tank.let me know if yall think it is factory i guess next time im near it i should look at the floor and see if it has holes for the lines. thanks Mike
02-13-2007, 09:13 PM | #2 |
Re: anybody ever seen a gas tank delete???
forgot the pictures
02-13-2007, 09:16 PM | #3 |
maybe this one is less blurry
02-13-2007, 09:24 PM | #4 |
i parted a very low mileage '69 1ton dualy camper a couple years ago where it had a large tank on the side of the frame and the one in the cab
'70 k-10 longbox- mid 70's drivetrain 350/350 487x heads 10.1:1 flowmasters ,35's 3.73's auburn posi ,rear shackle flip. '72 short stepside U.S. forestry truck, '73 455 buick,400 turbo,dropped 2"-4 1/4" ,3.07 posi,:'89 silverado 1500 ,OK truck ,5.7 holley tbi ,trick 700r4 3.07 auburn posi ,and my '66 skylark ,'73 centurion and my '84 monte carlo imca stock car |
02-13-2007, 09:58 PM | #5 |
yeah i've seen several with two tanks but only seen 2 that i can remember with no tank in the cab i still own the other one but i believe the fuel neck hole is welded up on the other one anybody else have any info on this? thanks Mike
02-13-2007, 10:58 PM | #6 |
Junior Member
Part #3997088 was a cover for fuel tank opening...it use to look like that so I am sure it's factory. Was more common on 40 series trucks with stake bed and "saddle tanks". I would say that was it.
Skip |
02-14-2007, 12:18 AM | #7 |
its all about the +6 inches
seen plenty on the C/40 and bigger trucks.
02-14-2007, 01:57 AM | #8 |
do you have any idea what "flasher unit" is? it's on the bottom left row of the glove box option list
67 short fleet 71 blazer 4x4 72 blazer 2wd 76 gmc sierra 3/4t 4x4 62 bel air 01 blazer extreme member 11,943! |
02-14-2007, 06:12 AM | #9 |
probably a HD flasher
02-14-2007, 07:10 AM | #10 |
Broken Down
I plan to weld my closed
kenm78 1982 Chevy 4X4 Project truck “It’s better to keep your mouth shut and let people wonder about your ignorance, than open your mouth and reveal all doubt” |
02-14-2007, 09:06 AM | #11 |
It`s factory alright.Pretty rare on a 1t.That`s a nice set of options.So,what was that trucks original purpose in life?I see it had a special paint option.What does it look like,that lime-ish green like some emergency equipment use?Very interesting.
02-14-2007, 12:41 PM | #12 |
My '68 motorhome has one, since it has the pass through from the cab into the motorhome. Saddle tanks on either side of the frame. It's not listed on the glovebox though and I'm sure it was done by the motorhome company (Open Road) as part of the conversion. They used a chrome "gas cap" that is permanantly installed in the opening.
'72 Chevy Blazer |
02-14-2007, 12:42 PM | #13 |
That is an interesting list of options. Tell us more.....
'72 Chevy Blazer |
02-14-2007, 02:27 PM | #14 |
Yeah kinda neat medium green metallic. i dont see any holes or crazy wiring.I got it as a cab and chassis and really dont see any kinda of welding on the frame other than the pieces that level the frame behind the cab, iassume those are the (body cross sil mtn) that is on the spid. the truck is available if anyone wants to add it to there collection cause mines getting to big!thanks Mike
02-14-2007, 09:19 PM | #15 |
I`m thinking RV.But,why the moved tank since it`s not a pass-thru.Unless it`s for more capacity.
