Old 02-15-2007, 05:08 PM   #1
kaycee
kaycee's Avatar
Cold Air Intake??
Can't seem to fork over the $ for a C.A.I has any one made one them selves?All I see you get in the kit is a high flow filter and a piece of pipe or hose and a new box.What is wrong with the stock box seems as though it would let more cold air in as opposed to the K&N BOX.How about a high flow filter and a homemade pipe.Am I missing something here
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327
kaycee is offline   Reply With Quote
Old 02-15-2007, 09:34 PM   #2
kevinr1970
Re: Cold Air Intake??
With enough determination you can do anything!
When I replaced my intake I noticed that the tube that goes from the filter to the throttle body is the most bizzar shaped thing i've ever seen. Have to wonder why it was designed the way it was. Maybe they tested it to that shape and determined that to be optimum?
On my filter box it was made so it only pulls air through two small holes in the fender. The new one shields on three sides (four if you include the hood when closed) and allows air through the two holes and the entire front area behind your headlight. From there it is almost straight down to the ground.
Realisticly you could get a cone filter and replace the box the stock filter is in with a home made sheild like they give you?
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 02-15-2007, 11:16 PM   #3
Gremlinafteru
I bought a high flow universal cone filter and mounted it on my MAF sensor through a piece of scrap aluminum i got froma local metal shop and bent around 2 sides towars the engine...i am still usin the stock air tube because i cannot find anything that is a 90 degree bend that 4 inches in diameter, but when i do i will reduce it to 3 inches and use fertalizer hose...
Gremlinafteru is offline   Reply With Quote
Old 02-16-2007, 10:37 AM   #4
bcj67chevy
402 BIG BLOCK
bcj67chevy's Avatar
What i did was take off the old intake tube part and cut off all the noise suppressors and irregularities and then fiberglassed the whole thing, this way it is just as smooth and will flow just as well as a k&n fpik kit. Then i got rid of the factory air box and made a heat sheild and put on a universal k&n air filter. Works awesome, plus it only cost me $70.
1967 C10 swb
1970 GMC Jimmy 4x4
2005 Chevy tahoe Z71
2001 Chevy impala
bcj67chevy is offline   Reply With Quote
Old 03-02-2007, 12:28 AM   #5
dinnut
dinnut's Avatar
i looked around a found a used trueflow intake for 100 bucks. uses stock box, have a k&n filter inside. replaces the tube from throttle body to the box.
allintakes for 4.8, 5.3, and 6.0's arethe same 2wd or 4wd. look around on chevytruckworld.com, performancetrucks.net, or ebay
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
