Old 03-14-2007, 04:35 AM   #1
cruisinlow67
window removal
i have a 67 small window cab we wanna scrap and i was wondering what the best way to remove thw windows is? without breaking them. also does the dash unbolt or is it "molded" in?
cruisinlow67 is offline   Reply With Quote
Old 03-14-2007, 07:50 AM   #2
Sammy
Re: window removal
Everyone has has their own ideas mine is to cut the inside of the entire lip of the seal push the seal / cut out from the inside with a helper to support the window & remove the glass carefully. As far as dash not sure but I think it requires spot weld removal from the cab which I have never done personally. Hope this helps!
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 03-14-2007, 07:54 AM   #3
Aarons72s
Re: window removal
I agree with sammy on window removal. Cutting the seal is the best way to get the glass out without damage. As for the dash, once you remove the windshield you will see spot welds from one side to the other that hold the dash to the windshield pinch weld. Drill those out. Not to hard to do, took me about 30 minutes. Once you undo the spot welds just undo the 4 bolts that hold the sides of the dash to the cab inside the cab and you are done. Good luck.
Aarons72s is offline   Reply With Quote
