Old 03-23-2007, 09:19 AM   #1
ChadMorris
Newbie truck Rebuilder!
Question 700R4 mount question
OK, I hang out in the 60-66 forum most of the time, but surf all of them for info, so hopefully someone here can help.......
I have a 700R4 tranny, and the mounting bolt holes on my new aftermarket crossmember do not line up.
This tranny came out of an 1985 corvette...
Question: Do they have different tailpieces for the tranny's?
Can I just swap it out if they do?
I would hope that's all I have to do seeing how common they are...
Any info will be great
Thanks for the help...
Chad
"Old Blue" 1964 GMC Fleetside in pieces
350 TPI with 700R4 tranny now installed( well kinda propped in place until the tranny crossmember is bolted in !!!!!
1995 Toyota 4runner , 197,000 miles and going...
2007 Honda Odyssey Van (Wifes car)
ChadMorris is offline   Reply With Quote
Old 03-23-2007, 09:23 AM   #2
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Re: 700R4 mount question
Does it not line up side to side or front to back ?
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 03-23-2007, 10:23 AM   #3
bagged91
Out draggin'
bagged91's Avatar
Check this thread. I posted a pic on there of the 3 different tailshaft housings... Hope this helps....
91 GMC Xcab LB-Bags/bd/caddy clip SOLD
72 C10 Cheyenne Super LWB SOLD
92 GMC K1500 Burb
72 C10 Burb (ex. Cheesewagon)SOLD
72 C20 Burb parts truck
71 C10 Burb "project"
bagged91 is offline   Reply With Quote
Old 03-23-2007, 12:54 PM   #4
ChadMorris
Sorry everyone, I should have been a little clearer....The holes on the tailpices of the transmission do not match up to the mounting holes on the crossmember.
The crossmember itself fits great!! I bought an aftermarket package from Performance Products: Engine mounts, tranny crossmember and mounts, and bolts....Al that fits fine.
here is a pic of how the tranny looks on the crossmember....
BAgged91 : Looks like I need the tailpiece for the Caprice.....That thread was a bunch of help.
Chad
Old 03-23-2007, 02:32 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
looking at the photo, you MIGHT be able to flip the X-member around, so the mounting tap is pointing to the rear. If there isn't enough room to clear the tail shaft from the main cross member like that, then you'll just have to slide it back a little, and drill new holes.
Old 03-23-2007, 02:50 PM   #6
ChadMorris
yeah, I will def have to drill new holes, just have to get a new tailpiece and figure out where to put the xmember.....Lots of fun .....
Old 03-24-2007, 08:58 AM   #7
cooters
just but a truck tailhousing and all your troubles go away. The pic that bagged 91 put in shows the middle tailhousing as astro but it is actually camaro/ firebird. The three holes go to the diff.
cooters is offline   Reply With Quote
