Old 04-06-2007, 06:11 PM   #1
1969k10stepside
Bed dis-assembly
So,I'm taking the bed apart that I just bought so I can blast it and prime it all and get all the rust.So,about half the bolts are out now.The front panel is ready to come off.The wheel tub on the passenger side is ready to come off too.So....everything unbolts,no welds to grind off,correct?I just plan to remove the tubs from the floor,remove the side panels from the floor,and unbolt the front panel from the floor....This is a fun thing to do (not!).The bed is upside down and 90% of the bolts get loose and spin under there so I have to get under there and put vise grips on them to keep them from spinning.....Hopefully,I will have pics of the bed all apart by Sunday.
1969k10stepside is offline   Reply With Quote
Old 04-06-2007, 06:18 PM   #2
Dano69c10
Dano69c10's Avatar
Re: Bed dis-assembly
Check out this thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=205466
Dano
'69 Fleet
It ain't yours, if you didn't build it!
Dano69c10 is offline   Reply With Quote
Old 04-06-2007, 11:13 PM   #3
qksilver
There are welds on the rear posts to the bed floor on the back rail/crossmember where the tailgate pivots are........sawzall them carefully
qksilver is offline   Reply With Quote
