04-20-2007, 11:36 PM | #1 |
I give up on Rallys!!
Okay, after getting sticker shock today at the tire store, and deciding the 15 x 10 rallys won't work for the front of my truck, I've decided to go low buck!!
A couple of questions first though. I need 2 - 5 on 5 front steel wheels for my truck. I guess 15 x 6 or 8 inch wide. Those are stock from what I gather from which years though? I also need 2 - 6 lug rear wheels, 15 x 6 or 8. What year are those from? Will the same Caps fit both the 5 and 6 lug? Will trim rings fit too? The funny thing is I have a complete set of 15 x 6 steel wheels for my Bel Air with new white wall tires on them, but they are 5 x 4 3/4. So close, yet so far. I will just do as Tx Firefighter did and paint them and install them. All I know is the wheels I have now have got to go! Moderators: After I get the years involved I will post the WTB in the correct section, just trying to do research right now. Thanks! Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE Last edited by jorgensensc; 04-20-2007 at 11:36 PM. |
04-21-2007, 12:00 AM | #2 |
Re: I give up on Rallys!!
Hhmmm.... I might know a thing or two about ralleys & steelies since I'm a recognized tightwad.
15x6.5" ralleys (van ralleys) are 5x5 bolt pattern. Most stock solid 'plain jane' steel wheels for 71-87 trucks are 15x7" 5x5 pattern. For 6-lug rear ralleys, use 73-87 4x4 Blazer ralleys. They're 15x8" w/4" BS & 6x5.5" pattern. If you're going the solid steelie route, the same model vehicle came w/7 & 8" solid steelies as well. I know the military versions were more likely to have the 8" wide versions. For trim rings, my personal favorite is the 88-98 Chevy truck steel wheel trim ring. They are shallow trim rings that only cover the outer most lip of the wheel (I don't personally care for deep trim rings or mis-matched trim rings on different size wheels). These are about 1.5" deep & easliy found @ most hub cap places, e-bay, swap meets, & wrecking yards. They make the outward appearance of the wheels uniform, even when running wider rear wheels. As for center caps, if you run solid steelies, the same 'truck' cap will work regardless of the bolt pattern. I emphasize truck because car-pattern wheels & truck pattern wheels use different size 'dog-dish' caps. Full wheel covers are universal. Ralley centers are obviously specific for the bolt pattern. I've seen 5-lug front late model caps & 6-lug rear late model caps on the same truck & it didn't look bad.... but you did notice if you studied the truck. If you run 'poverty/dog-dish' caps or full wheel caps, they hide the bolt pattern all together so no one but you will know if somethings not the same. . .....
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 04-21-2007 at 12:04 AM. |
04-21-2007, 12:05 AM | #3 |
Well, this may not be perfectly correct but...
5 on 5 rally's came on 73-80's(?) in 15 x 8 width... the 5 on 5, 15x 7's (6-1/2?) were on 1/2 vans... The 6 on 5-1/2 bolt pattern were on 4 x 4 1/2 ton trucks, I'm assuming 73-80's(?) again.... I also belive the trim ring were the same for 8" wide regardless of 6 or 5 lug,... although the 7" (6-1/2?) or narrower used a different trim ring... And... the center caps all interchange on the 5 on 5 bolt patterned wheels... but the 6 on 5-1/2 would not work... the center caps fit over and around the bolt holes... so, I hope all that helps... others may know more specifics, but... junk yard hunting this above info works for me...
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White 2002 Chevrolet 1500HD 4x4 Crew Cab 6.0L 4L80E Red |
04-21-2007, 12:21 AM | #4 |
STOCK STEELIES
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
04-21-2007, 12:22 AM | #5 | |
i wont report ya
04-21-2007, 12:29 AM | #6 |
HMMMM!! Hubcaps, HMMMMMMM I'm starting to brainstorm.....
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
04-21-2007, 12:36 AM | #7 |
why wont 15x10 ralleys fit on the front my 71 has 15x10 chrome ralleys on it no rubbing or mods need
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
04-21-2007, 12:37 AM | #8 |
Well, Whoop-dee-do!
Not all vans had 5 on 5, some light gvw 1/2 tons in the late '80s & newer had 5 on 4-3/4.
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD '72 K20 500 Cad/TH400/NP205 SOLD '92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver '72 Monte Carlo... sweet low mile toy '11 Dodge Challenger IE 392 6spd... midlife car |
04-21-2007, 12:47 AM | #9 |
If it's a van & it has ralleys, it's 5x5.
04-21-2007, 12:54 AM | #10 |
Well, Whoop-dee-do!
I'm all but certain the '89 van I use for storage is 4- 3/4. It came with Ralleys. They are still on it- I think. It's 140 miles from here- next time I'm there, I'll look.
04-21-2007, 01:00 AM | #11 | |
Shawn
04-21-2007, 01:02 AM | #12 |
Are you sure car caps won`t work on truck steelies?Is this true for early`50s cars?Because my first truck was a`72 shortbed Highlander that I put wide steelies on with,I think,`54 caps.
04-21-2007, 01:13 AM | #13 |
LOVE the wide whites and i bet the bel air caps would look awesome on it and best part is itd be different, cant wait to see what you come up with
04-21-2007, 01:17 AM | #14 |
This statement is not an absolute. That being said, most car pattern caps are 9 1/8" dia & truck pattern caps are 10 1/8" dia.
04-21-2007, 11:32 PM | #15 |
Chevy Van's 71-74 1/2ton's were 5 on 4-3/4... I used the spindle, caliper, & rotors on a past truck in order to get that bolt pattern... they use the same ball joint (upr/lwr) and same tie rod end... but use 71-77 camaro rotors & caliper, & pads...
the 71-72 van spindle use a 71-72 P/U tie rods end and the 73-74 van use a 73-later P/U tie rod end.... but are 5 on 4-3/4 bolt pattern... I had a car 12 bolt rear end in it and ran corvette style rally's 15 x 7's up front and 15 x 8's in rear... Never heard anything about later trucks being 5 on 4-3/4.... Gotta love rally's....
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White 2002 Chevrolet 1500HD 4x4 Crew Cab 6.0L 4L80E Red Last edited by 67 cst swb; 04-21-2007 at 11:33 PM. |
04-21-2007, 11:50 PM | #16 |
too late your being watched...
