Old 04-29-2007, 09:06 PM   #1
69BBsuburban
Right in front of you.
69BBsuburban's Avatar
Question Help needed: swapping out 292 for a V-8 in a 4x4
Tech question here, not sure if I should post this in the engine, 4x4, or this section....but here it goes....
Have a '69 Suburban 1/2T 4x4 with a 292. I pulled the 292 out, going to get a Big Block.....anyway, the crossmember is angled as the motor mounts are off-set. See pics.....that's a spare 454 block I had laying around for mock-up. The driver's side pretty much lines up, although once heads and V/C's are on it I think it'd be a tight fit.
What stuff do I need to swap in the V-8? Are all 4x4 V-8 crossmembers the same??? I assume I'll need motor mounts/towers as well.
Any help with this greatly appreciated!!!
I plan on getting the parts ASAP....
Pinstriping by Josh
'78 Chevy Silverado SWB (lowered, 454)
'90 Chevy Sport Truck
'68 Dodge Charger R/T
1930 Ford Model A
69BBsuburban is offline   Reply With Quote
