1968 Chevy 1/2 ton towing capacity
I have a 68 c10 with a 350, and 4 speed tranny, what is the towing capacity on these? I'm not sure what gears it has, is there anyway to check?
1968 c10 Chevy 2005 Infiniti G35 2006 Subaru WRX STi ![]() |
Re: 1968 Chevy 1/2 ton towing capacity
Pull the rear end cover and on the ring gear there is some numbers like 41:11,ect.
Compare those to the numbers below and you have your ratio Ratio 2.56:1 - Tooth Combination 41,16 Ratio 2.73:1 - Tooth Combination 41,15 Ratio 3.07:1 - Tooth Combination 43,14 Ratio 3.08:1 - Tooth Combination 40,13 Ratio 3.08:1 - Tooth Combination 37,12 Ratio 3.31:1 - Tooth Combination 43,13 Ratio 3.36:1 - Tooth Combination 37,11 Ratio 3.42:1 - Tooth Combination 41,12 Ratio 3.55:1 - Tooth Combination 39,11 Ratio 3.73:1 - Tooth Combination 41,11 Ratio 4.10:1 - Tooth Combination 41,10 Ratio 4.11:1 - Tooth Combination 37,9 |
gracias!
its all about the +6 inches
you'll need that info to determine what your towing capacity is.
Really? Seems like brakes and springs would determine towing capacity.
72 C2500 LWB 402 Sierra Grande 05 Odyssey 08 Tundra |
Think of it this way,you may have the biggest brakes in the world and 1 ton springs but your truck and 3:08 gears wont tow a trailer up a steep hill.Need lower gears to tow.Atleast 3:73s IMO,maybe 4:10
Son of a gun
I swiped these off the board a couple of months ago. Once you know your ratio, I'll tell you how much trailer you can haul. I know they are a little hard to read, but if you squint you can make it out
Bill BEATERS ARE NEATER |
Thread Tools | |
Display Modes | |
