09-11-2002, 01:47 AM | #1 |
A-arm question
I'm converting a 67 C-20 2wd Chevy to a C-10. Can I use the C-20 A-arms, upper and lower, or do I need C-10 A-arms? Is there any difference between these?
09-17-2002, 01:26 PM | #2 |
As far as I know they're the same, but it's the assemblies and springs that are different. The actual control arms themselves are the same. Also, I think the tie rods and sway bars are different...I know the sway bars are.
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
09-18-2002, 04:22 AM | #3 |
I was hoping to hear that the control arms themselves are the same between 3/4 and 1/2 ton. I had planned on replacing everything else anyhow, like the springs, spindles, ball joints, ect. I just didn't want to have to go looking for new control arms. Thanks for the information!!
10-01-2002, 03:46 PM | #4 |
Fabricate till you "puke"
The upper arms will work,but the lowers wont(different hole size for the ball joint on the lower arm). You will need to replace ball joints& outer tie rod ends as well to bolt on the 1/2 ton spindles. good luck......Crazy longhorn
