Old 05-23-2007, 07:55 AM   #1
Tink
Tink's Avatar
Wiring for lock-up converter on 85 THM350?
We recently replaced the 305 in our 85 Silverado with a rebuilt one from a 70s car. When we removed the old 305, we ditched a lot of the computer and emissions BS. However, it seems that we must have gotten rid of whatever fed/controlled the lock-up torque converter on the TH350 - it doesn't seem to be working now. Can someone here tell me what the wires are that feed it and what not?
69 Chevy C10
88 Sierra
02 2500 Suburban
And too many S10s to list!
Tink is offline   Reply With Quote
Old 05-23-2007, 07:37 PM   #2
78Chevy
78Chevy's Avatar
Re: Wiring for lock-up converter on 85 THM350?
Okay, I don't know if this will help or not, but I have attached a couple of wiring diagrams for an 85 305. I know that you have replaced the 85 with one out of a 70's car. I'm not a 100% sure, but I think that the ECM that controls the engine also controls the trans. Also, over in FAQ on the secound page of Truck Tech there is a post that says Turbo 350c Lock Up Wiring by dhill it has a wiring diagram for the trans, but I don't know whether or not it will help you if it went through the ECM.
Good luck
Al
97 K1500 Tahoe 5.7 Stock "Driver"
78 swb C10 Silverodo/ 350cu. dual Flowmaster's, MSD cap, and wires. "Project"
LONG LIVE AMERICA!!
78Chevy is offline   Reply With Quote
Old 05-23-2007, 08:30 PM   #3
Ivan D.
glamoros piece o' lowlife
Ivan D.'s Avatar
Is it possible to run the lockup to a switch that you can engage manually?
The more I drink, the more I drink, the more I drink...
diesel, reg cab, long bed, 4 across the rear, single stack, wooden stakes, and lotsa lights - the Hay Express
Ivan D. is offline   Reply With Quote
Old 05-24-2007, 01:21 PM   #4
BADGMC
BADGMC's Avatar
Yes you can hook it to a manual switch. I don't remember which pins to hook up to on the trans though. There are a few sites around that explain it really good. I will try to remember what they are.
85 GMC 1/2 ton LWB 4150lbs.
383 SBC with Twin MPT70 Turbos 850 CSU carb
TH375 3.70 gears Ultimate 10" Converter
10.11@136.6 with 1.64 60ft. on 10.5-31-15W
BADGMC is offline   Reply With Quote
