06-08-2007, 09:48 AM | #1 |
steering column mount
quick question i am droping in a standard chevy stering colom in my 53 what size of top mount do i need? locar list several drop distances 2" 3" 4"... what are you guys using???? oh and what should i use on the floor. i've seen a lot of guys use something like a pipe to hold the bottom in... so many questions... throttle peddle, what should i put on the floor for my 350? i would love to use the stock throttle mount and peddle but the holly probably needs some sorta a cable...
thanks guys GREG http://67-72chevytrucks.com/vboard/s...d.php?t=215079
Greg 1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school http://67-72chevytrucks.com/vboard/s...=215079&page=5 Last edited by mylow53; 06-08-2007 at 09:49 AM. |
06-08-2007, 10:31 AM | #2 |
Re: steering column mount
Are you using the stock seat?
I am watching these answers also, as these questions will come up latter in my build.
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
06-08-2007, 03:20 PM | #3 |
a seat that should match the stock height from glide
Greg 1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school http://67-72chevytrucks.com/vboard/s...=215079&page=5 |
06-08-2007, 06:58 PM | #4 |
Im going to use exhaust clamps, but my column is different than yours I think.
I dont have tilt either so my height will be off as well.. I just realized how pointless my post is... |
06-08-2007, 10:47 PM | #5 |
I used the stock mount and fab'd a cover for the floor. The column is a chevy van w/ the key on the dash.
Try using a broom stick and paper plate to mimic your steering column. Be sure to be sitting at the height and proper distance. |
06-08-2007, 11:25 PM | #6 |
I went with an Ididit tilt/shift column and I used a billet swivel floor mount. I also bought a piece of 2.25 inch exhaust pipe to mock up so that I didnt scratch my chrome column.
Exhaust pipe comes in many different diameters so this may work for you as well. I went with a 5" drop because I made a custom lower dash panel that will house all of my A/c controls and vents. Good luck. Marc |
