Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 06-09-2007, 08:35 PM   #1
chevyboy55
chevyboy55's Avatar
Stereo Amp help
My son & I are finally about finished with his truck(pics will follow)
Well today when we were putting the stereo back in we hooked up the amp & subs & nothing! We have power going into the amp but no sound comes out of the subs. Now I will be the first to admit that I don't know squat about stereos.
Should I have power at the speakers(checking with a test light?) I don't have any. It worked fine a year & a half ago when we tore it apart to paint.The stereo works fine when playing through the 6x9's & dash speaker.It's a 1000 watt Alpine amp. Ground is good(we used it to test power coming in) I'm just trying to throw all info I can out here.Any ideas?
Great minds think alike,So do ours
chevyboy55 is offline   Reply With Quote
Old 06-09-2007, 08:50 PM   #2
GREASEMONKEY72
GREASEMONKEY72's Avatar
Re: Stereo Amp help
are the subs in a box and youre hooking the wires up to the clips on the box? if so pull the speaker out and make sure the wires didnt fall off inside, happened to me
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 06-09-2007, 09:18 PM   #3
Alexis
Member since 2000
Alexis's Avatar
Re: Stereo Amp help
check the fuses on the amp. Also check if the "amp wire" form the head unit is not the antenna wire, also make sure to test it. But check fuses first. If you have a nextel we can talk over the radio. I use to work un car audio so I might be of some help.
Also "working backwards" when trying to find troubled wiring seem to work best. Start at the amp then go back retracing each wire.
Alexis is offline   Reply With Quote
Old 06-09-2007, 10:39 PM   #4
corn
Re: Stereo Amp help
Im guessing its the rca connectors either on the head unit or on the amp not hooked up or the remote turn on lead unhooked. Id start at the remote turn on lead. Your test light wont be any help on the speakers. Does the amp light up when powered up?
corn is offline   Reply With Quote
Old 06-09-2007, 10:42 PM   #5
shifty
Questionable
shifty's Avatar
Re: Stereo Amp help
Is there a power light on the amp?
if yes, i don't know what to tell you.
if no, then all you should know is this: you MUST hook up three wires to make the amp turn on:
12V+ power
Ground (must be a good ground!!)
Remote Turn-on lead (this is usually a blue wire from your head unit to the amp)
As a temporary solution to check things out, you can run a 18ga jumper from the 12V power line to the turn-on lead.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 06-10-2007, 12:33 PM   #6
chevyboy55
chevyboy55's Avatar
Re: Stereo Amp help
I hope I don't look as stupid as I feel.The blue remote turn on wire was not connected Kinda cool how things work correctly when everythings hooked up.
Old 06-10-2007, 12:45 PM   #7
shifty
Questionable
shifty's Avatar
Re: Stereo Amp help
I've seen more people than you know forget that!! (hence why i mentioned it )
Old 06-10-2007, 12:55 PM   #8
redneckgirl
redneckgirl's Avatar
Re: Stereo Amp help
I moved this to 'Truck' Audio....
even though you got your problem fixed, I thought it might serve as a good reminder for others
The place where you made your stand never mattered. Only that you were there... and still on your feet.
Stephen King
redneckgirl is offline   Reply With Quote
Old 06-10-2007, 01:01 PM   #9
boatpuller
boatpuller's Avatar
Re: Stereo Amp help
sheeesh..........leave it to you kelso guy's.
" Never look up a dead dogs butt."
boatpuller is offline   Reply With Quote
