Old 06-13-2007, 01:24 PM   #1
bufmatmuslepants
Junior Member
500 mile trip, what gas milage to expect
i have to figure out if i can afford the gas to drive my truck from school here in WV to home in CT. its about 500 miles, and if im gettin 10mpg thats 50 gallons x $3 a gallon = $150. its a stock 79 K10 turbo 350 350 4 barrel, NP203 case, has the stock cat and muffler on it and the pipe out of the muffler is about 2 inches diameter..maybe less. stock intake and 33x12.5 tires. anybody have any guesses on what gas milage ill get on the highway with this thing?
1979 K10 reg cab short bed 33x12.50s - GONE
1988 4x4 reg cab long bed 337k miles - GONE
1995 Z71 GU6 G80 F44 ext cab short bed 149k 305/70/16s - GONE
1995 NZZ GT4 2dr Tahoe 3" lift 14 bolt sf 155k 305/70/16s - GONE
1994 Z28 M6
1995 Z71 GT4 G80 ext cab short bed 215k GONE
1997 GT4 G80 Yukon 4 door leather, sunroof 168k miles GONE
2003 Avalanche Z71 GT4 G80 165k miles
bufmatmuslepants is offline   Reply With Quote
Old 06-13-2007, 01:35 PM   #2
benoit454
Chris
benoit454's Avatar
Re: 500 mile trip, what gas milage to expect
Man that's a full time 4x4 case in that thing I'm surprised with that, the th350 and the 33's you get 10 miles to the gallon.
Our 86 was a 208 part time case, we ran in 2wd all the time, it had 33's and 3.08's with a 700r4 and only got 10 mpg around town. The highway seemed better though.
I say if you are lucky maybe 15-20 on the highway. More then likely 10-15 mpg.
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 06-13-2007, 03:08 PM   #3
kevinr1970
I got ~12.5-13mpg with about 90% freeway (70mph) last time I checked.
1986 1/2 ton 4x4 in 2wd, 350, 700r4, 3.73 gears.
That was with a carb that didn't want to accellerate off idle very well so you ended up juicing it pretty good to get it rolling. I think that might pick up a smidge now that the carb is behaving better.
But I think that 14mpg might be the best I could hope for.
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
