Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 06-27-2007, 05:34 PM   #1
jorgensensc
jorgensensc's Avatar
Satellite radio Question?
I was thinking of running sat. radio in my truck and running to an amp and out to speakers.. I don't really want a head unit, just hidden sat controls behind radio delete plate. I just realized I couldn't really control the volume this way. Does anyone have any suggestions to control volume?
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 06-27-2007, 06:54 PM   #2
JameslovesJammie
God Bless Mr. T
JameslovesJammie's Avatar
Re: Satellite radio Question?
What do you currently have for a radio? The reason I ask is that there are basically 2 different ways to hook up a satellite radio-FM Modulated or through a direct connection from a satellite tuner to your receiver.
The FM Modulated way is by far the easiest, but in the same breath your sound quality is only as good as FM radio. Direct connection is more expensive, but will give you better sound quality.
If you're just running the stock AM radio, you may be out of luck, unless you do some type of retrofitting to hook it up. There is a thread somewhere on here where someone took the AM radio and made it MP3 compatible. Depending on your electrical know-how, that may be a viable option for you.
Like a midget at a urinal...sometimes you must stay on your toes.
JameslovesJammie is offline   Reply With Quote
Old 06-27-2007, 07:53 PM   #3
jorgensensc
I currently don't have a radio at all, But I have a radio delete plate which I'm thinking of using to cover the sat radio face. I read that thread about the am radio and like it a lot, but I think I would like to run a Sat radio somehow.
Shawn
Old 06-29-2007, 01:52 AM   #4
AceX
>130dB Moderator
AceX's Avatar
I'm going to assume that you are running a seperate, portable module.
What you have to remeber is that these modules do not have a digital signal output. Many of them rely on FM modulation or an analog connection to carry their signal.
What you would have to do is get a cord with a headphone jack on one end and a set of RCA's on the other and use that as the signal to an amp which will run the speakers.
Living Life @ 130dB
LED Tail Light Conversion; How-to
Friend. Father. Brother.
RIP El Jay
CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum.
AceX is offline   Reply With Quote
Old 06-29-2007, 08:16 AM   #5
7T2
Active Member
7T2's Avatar
I don't see why it wouldn't work? Both of the satellite radio receivers I own have an audio out jack and a volume control on them. You should be able to run that directly into the amp and use the volume control on the satellite receiver.
1957 GMC Ambulance
1962 Belair Wagon
1963 C80 Truck Cab *FOR SALE*
1969 Chevy C10 Short Bed
1972 Chevy C10 Long Bed *SOLD*
1996 C3500 Dually *SOLD*
7T2 is offline   Reply With Quote
Old 06-29-2007, 03:08 PM   #6
bodydropped
imm runnin xm thru my indash it plus it plugs right in but draw back i wish my screen took sirrus because xm sucks i hear the same songs atleast 3-4 times a day
bodydropped is offline   Reply With Quote
Old 06-29-2007, 04:14 PM   #7
Hook'em
Hook'em's Avatar
I have one of the Custom Autosound crappy radios. I almost junked it last year when the FM stopped working. But I was happy this year that I had the ability to direct connect my XM Sat through the jacks in teh back. Now I only use the radio for AM sports talk and use the XM for music and news. I would really like to have a factory radio with imput jacks installed, but that is too high $$ for me right now.
Hook'em
Hook'em is offline   Reply With Quote
Old 07-01-2007, 08:59 PM   #8
Pyrotechnic
Pyrotechnic's Avatar
http://www.maxxsonics.com/hifonics/sigproc_XEQ.html
http://www.maxxsonics.com/hifonics/sigproc_ipod.html
Check out those products from Hifonics. I think the HFEQ or the MM-1 are what you are looking for.
Pyrotechnic is offline   Reply With Quote
