09-18-2002, 07:20 PM | #1 |
radiator catch can ideas
i need pics/ideas of radiator catch can/overflow because i'm going to try to take my truck to the track next weekend.
my truck has a/c so i cant put it on the passenger side of the radiator and i have my electric fan box on the driver's side so i cant mount it there. i would like to use one of those plastic ones from summit but dont know how to mount it. how about the factory ones? arent they on the fender?
68 short step, 406/700r4, 9" w/discs. |
09-18-2002, 10:41 PM | #2 |
I added a catch can from some type of import car. It's small, and I mounted it beside the battery. It's on the fender side and is mostly out of view and bolts to the battery box. Passes tech with no problem. Just go to a wrecking yard and see what's available.
69 C-10 CST Short Fleet, Factory Air, BB427-400 Auto-2400 stall-tilt-cruise-Tach & Vac Gagues, 4/6 drop, power one piece side windows, Eaton posi. |
09-18-2002, 11:24 PM | #3 |
its all about the +6 inches
Windshild washer bottle mounted on the rad support under the battery.
09-18-2002, 11:29 PM | #4 |
I got a nice big bottle from an 82 Camaro. Mounts nicely on the pass. side inner fender, contoured back and all. Sorry, not the best pic but you get the idea.
1970 GMC 1500 Custom Original 350/TH350 Victoria, BC, Canada You can wish in one hand and crap in the other. See which one gets filled first. |
09-19-2002, 01:24 AM | #5 |
14.1 @ 96MPH
Did GM ever offer them as stock? Mine has one mounted on the driver's side, on the core support...I doubt it's stock, but it looks old enough to be so. *shrug* It works.
Project1970 - LS1 Swap Complete! |
09-19-2002, 02:16 AM | #6 |
"TRUCKLESS"
My brother in law is to lazy to put one on, so he just has a pepsi can zip tied to radiator support with a hose going into it. Lazy way of doing it but it's legal at the track.
Mitzki5 No longer have an old truck! But always looking for another one! |
09-19-2002, 02:36 AM | #7 |
not bad so far, keep the ideas comin. pictures, i want pictures!!
anyone have any pics of the aluminum nice ones that are out there? i'd like to do one of those but its school time and i'm limited on funds.
09-19-2002, 07:20 AM | #8 |
Took mine off!
I have one of those aluminum ones I just took off this summer. Cant say if it worked or not. I had it mounted on the outside of the radiator support to the passenger side and didnt care for the fact that u could see it through the grill. It was about 15" long.
09-19-2002, 09:07 AM | #9 |
Project1970, The coolant overflow bottles were a dealer installed option in the later years (probably 71-72), that could be what you have.
V-6....only GMC Trucks have it! 62 GMC W5000 NAPCO-V6 65 GMC 2500 NAPCO Panel-V6 66 GMC 1000-V6 66 GMC 1500-V6 67 GMC K1500-SBC (originally a KM-V6) 68 GMC C1500-V6 68 GMC C1500-V6 68 GMC Suburban C2500 70 Chevy K20-SBC 71 Chevy C30 Longhorn-SBC 72 GMC Suburban C1500-BBC 72 Chevy C10-SBC 72 GMC C5500-ToroFlow Diesel |
09-19-2002, 11:19 AM | #10 |
My friend uses a one liter Captain Morgan Bottle mounted to the radiator support. Looks cool, why not...
1967 GMC Custom 8ft Fleetside 292 L6, 4spd. 1973 Oldsmobile Delta 88 Convertible 455, TH 400 1969 F#$% Bronco 302, 3spd 4.11's 1958 Oldsmobile Super 88 Fiesta Wagon |
09-19-2002, 11:57 AM | #11 |
SKINNY TIRES RULE!
He uses a glass bottle? If the glass is cold and hot fluid goes into the bottle, it could shatter. That would be a bigger mess than coolant on the ground. I'd stick with plastic or the pepsi can.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
09-19-2002, 12:03 PM | #12 |
I suppose you're right, it could shatter, but he's had it on there for a year+ and survived a winter even... maybe he lucked out and got a sturdy bottle. But it probably is a good idea to use something that won't shatter.
09-19-2002, 01:15 PM | #13 |
Not my good side.
I bought mine from PepBoys for about 8 bucks. Came with a wire basket to mount it, clear vinyl tubing, and some micky-mouse hose clamps (which I tossed & substituted real ones for). Not the prettiest, but functional.
Here's my first attempt to attach a photo...
72 Chevy K20 Custom Camper, 350/350, 4" lift, dual shock suspension front & rear. Daily driver and a work in progress. 00 Suburban LT 90 Camaro RS 79 Yamaha XS1100 Special (Ol' Reliable) |
09-19-2002, 01:17 PM | #14 |
Not my good side.
Hey, it worked! Here's the other side:
09-19-2002, 08:44 PM | #15 |
My 72 Truck has the Dealer installed overflow bottle. It's mounted on the passenger side inner fender. It is fairly large, looks like it would hold about one gallon.
72 Chevy A/C P/B P/S Tilt 454 Engine 400 TCI Trans C30 Frame C10 Suspension Short Wheel Base (Dually) |
09-19-2002, 10:58 PM | #16 |
Illisatration of the factory (dealer) style...
09-20-2002, 12:02 AM | #17 |
hey mudder67, any pics of it before you took it off? couldnt you mount it far enough to the side that you couldnt see it through the grille? how'd you run the tube to it?
09-20-2002, 07:25 AM | #18 |
Old member
Here you go!
Mid 80 Chevy. car overflow.
09-23-2002, 09:44 PM | #19 |
how do the summit plastic ones and the nice looking aluminum ones mount?
09-23-2002, 09:49 PM | #20 |
the summit plastic ones have 2-1/4X20 screws in the back of it.
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
09-23-2002, 10:03 PM | #21 |
maybe they won't even check for it, some places are lazy, it all depends
