06-30-2007, 10:40 AM | #1 |
Junior Member
14 bolt disc conversion
I know this topic is widely covered. But I have seen so many different types on ebay for sale ( brackets basically ). I am hung up on the spacer issue. I have seen some with dom tubing spacers, black pipe, small angle pieces welded on bracket, and a really neat set with machinged aluminum spacers. I realilze the brackets are pretty much 3/8's laser cut steel. but whats the opinions on the spacers. Any one have any failure either way. Thanks a bunch for the info.
1969 impala conv 427 #s loaded. dad bought new 1969 "Judge" RA-3, rare warwick blue/white, #'s 1968 vet convertible #s 427/435 tripower (sold) 1968 belair 2door post #s 427/385 1936 ford 5w coupe dads 1st car 1969 camaro ss (17,xxx) miles Wanted: 69-72 suburban project, 69 camaro convertible. also any big block cars. 69-70 gto judge project. |
06-30-2007, 03:14 PM | #2 |
Location: vacaville ca, because it as far from indy as i can be
Re: 14 bolt disc conversion
DONT USE SPACERS,
the best brackets to get are from sky manufacturing, they are 3/8" plate steel and are pressed/broke and bent over to the correct distance. they are $90 but they are very nice and will not slop and slide like the flat plate spacered versions. http://www.sky-manufacturing.com/ in the chevy section. |
06-30-2007, 04:15 PM | #3 |
River life......
Some of the brackets on egay look scary to me because of the reasons you posted above.
I have DIY4X brackets, they are great never had any problems with them at all. Kert has superb customer service also, which can't be said for all mfrs. Although do use a spacer, per say, it is as beefy as you can get. DIY4X brake page I have used SKY products also, and maybe I caught them at a bad time, but I was lied to for a week about my items. Until I told them I wanted a refund and then the truth came out and my item shipped. May be an isolated incident, but it left a nasty taste in my mouth. Here is the DIY4X brackets
06-30-2007, 05:53 PM | #4 |
These are the ones I used and there only http://www.ruffstuffspecialties.com/catalog/index.php only $45 if you order them from here http://pirate4x4.com/forum/showthread.php?t=477819
Earl 68 2500 4x4 GMC Burb Last edited by earl87gta; 06-30-2007 at 05:56 PM. |
07-01-2007, 09:22 AM | #5 |
Junior Member
Thanks for the information guys. I will definately go with one of the two "bent" bracket approaches. The 2 sets look pretty much the same, and the one is half the price. Kinda puts you in that state of mind where you wonder either one is priced to high, or the cheaper one is cheaply made
07-01-2007, 11:07 AM | #6 |
I used spacers for years on a truck I don't own anymore and never had any problems---although once everything was in place I welded the spacer to the housing on the original flange
07-01-2007, 05:25 PM | #7 |
Ruff stuff sells them as quick as he can get them there has to be a few 100 people on pirate running them so I dont think its cheaply made. he says he makes his proffit off volume not high pricing. the set I have look as stronge as the stock d44 caliper brakets on my front axle.
Earl 68 2500 4x4 GMC Burb Last edited by earl87gta; 07-01-2007 at 05:27 PM. |
07-01-2007, 06:52 PM | #8 |
i dont like the ruff stuff ones because of the bolt hole in the center of the span. i think they are going to be prone to tear ing much like the early disk brackets did. skys are thick in that area.
i have sky's and would buy them again even though they are more$$$ i got mine in about 4 days. |
07-02-2007, 12:02 AM | #9 |
Ya they could use a little more meat up there but Ive neever herd of any of them failing. I like the Sky and DIYs too but Im cheap.
Earl 68 2500 4x4 GMC Burb Last edited by earl87gta; 07-02-2007 at 12:03 AM. |
07-02-2007, 12:27 AM | #10 |
Hey guys which rotors and calipers would I need. I believe the calipers are basic 70 gm calipers, how about the rotors? If I want functioning E-brake do I need eldorado calipers? what years?
68 4x4, 454, 4 speed, disk brakes both ends, Sold my 69 SS396 Elcamino when young & stupid |
07-02-2007, 01:48 AM | #11 | |
Active Member
Here is where i got mine and they do come with levers. http://www.tsmmfg.com/3121.htm
Mike T. Oregon 70 GMC Jimmy 4x4 70 Camaro LS1 plans in the works 71 RS/SS Camaro numbers matching 86 Chevy Silverado SWB 4x4 (454 merlin heads, 3/4 running gear upgrade, Detroit lockers front and rear) |
07-02-2007, 12:12 PM | #12 |
we are always another option.. We are on here and Pirates.
www.blackbirdscustomtrucks.com Plus we support the board.. We do complete custom kits. No guess work and warrantied.
Support The Board |
07-02-2007, 08:58 PM | #13 |
Thanks on the calipers, but what do I get the rotors from?
07-02-2007, 10:24 PM | #14 |
any 8 lug d44 or 10b chevy, they are $25 brand new from parts places
07-02-2007, 10:24 PM | #15 |
Active Member
Should be able to get them at any auto parts store. You just need to get 3/4 front rotors. 73-87 should work.
07-05-2007, 08:17 PM | #16 |
Thank guys
07-05-2007, 10:12 PM | #17 |
what brackets use the stock front truck calipers???
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
07-05-2007, 10:13 PM | #18 |
ord brackets says they do...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
07-05-2007, 11:49 PM | #19 |
