Old 07-03-2007, 02:27 PM   #1
bama51
Another temp gauge question
Hey gurus, I'm having problems with my temp gauge, and I've searched the forums to no avail. I have also looked at wiring diagrams trying to decipher them. Basically, I have a new sending unit, and a new dash. The wire in the dash cluster plugin for the sending unit shows no resistance from under the hood to the plugin (that's expected, right?).
The question is what about the other side of the gauge? It appears that in tracing the printed circuit board, the voltage side is common to the Fuel Gauge and brake warning light feed. This wire has no voltage on it, which makes me think it is my culprit, but I don't know where it goes on the other end. Anyone know?
bama51 is offline   Reply With Quote
Old 07-03-2007, 11:07 PM   #2
jhow66
jhow66's Avatar
Re: Another temp gauge question
Have you grounded the green wire off the sending unit to see if the gauge moves? To see if that circuit is powered, turn on switch and remove tan wire off prop. valve and ground it . Brake light should on dash should come on. If not , check your fuse.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 07-05-2007, 08:58 AM   #3
bama51
Grounded the prop. valve wire, and no brake light. Also checked the fuses and all are good. Any other suggestions?
Old 07-05-2007, 11:05 AM   #4
jhow66
jhow66's Avatar
Next take a test light and check to see if you are getting power to that fuse.
