Old 07-03-2007, 11:14 PM   #1
rdporterjr
Wobbeling first steps
I talked my wife into letting me buy my dream truck, a '69 Chevy short bed step side. The guy I bought it from said it just needed an alternator and it would be good to go. So I bought it "AS IS". Wrong answer. So here it goes.
The alternator didn't do it. I found out that the wiring was toast. So I got another wiring harness from the Pull A Part. It had it's problems but I was able to replace the bad wires with out a problem. I then installed it.
The starter was toast too. I got another and was having problems connecting the wiring cause the new harness seemed to have an extra wire. I think I got that figured out. Thanks to pjmoreland and his answer http://67-72chevytrucks.com/vboard/s...d.php?t=182535
BUT! it's still a NO-GO. So I'm needing help with getting this thing started. What else should I look for?
Specs:
Block numbers say its a '58 283 w/ points style distributer. Considering a swap.
4 speed transmission
rdporterjr is offline   Reply With Quote
Old 07-03-2007, 11:30 PM   #2
RED72blazer
urban fourwheelin
RED72blazer's Avatar
Re: Wobbeling first steps
Does the truck crank? Or just nothing. are you sure the engine isn't frozen?
Oh and Welcome to the board from Seattle!
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage.
RED72blazer is offline   Reply With Quote
Old 07-03-2007, 11:37 PM   #3
rdporterjr
It doesn't crank it doesn't do much. I have some receipts saying that the motor was rebuilt recently. However the install was a hack job. The more I look at it the more I see wrong.
Old 07-03-2007, 11:41 PM   #4
RED72blazer
urban fourwheelin
well I would stick a socket on the end of the crank pulley and see if it turns over. I'm heading down that way this weekend, I can try and stop by and help you if I have time.
Old 07-03-2007, 11:45 PM   #5
rdporterjr
I'll do that.
Send me a private post with your number when your in route.
Old 07-03-2007, 11:59 PM   #6
rdporterjr
I just went to the garage to turn the crank and I found that there isn't a bolt in the center, it just looks like a counter bord blind hole. The pulley has 3 bolts in it so I grabbed one of those and the crank doesn't turn. But I should still hear the starter click shouldn't I?
Old 07-04-2007, 12:03 AM   #7
RED72blazer
urban fourwheelin
Last time I tried to turn over a stuck engine the starter didn't make a sound.
Old 07-04-2007, 12:07 AM   #8
rdporterjr
Huh!! Thats bad news.
But I just realized that my clutch isn't disengaging either. The Push rod from under that dash is just bending when you press the pedal.
Old 07-04-2007, 12:12 AM   #9
stllookn
Saving 1 truck at a time!
stllookn's Avatar
If it is a stick, put it in gear...3rd or 4th, let the clutch out, key off, go around front with the hood up and rock it. You should see the fan turn a bit when you are rocking it.
Pull all the plugs and it will turn over much easier.
Check to make sure you have a good battery 13 volts. Check all the fuses and check to see that you have 13 v. at the starter with the key on.
Start with all of the basics.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 07-04-2007, 12:21 AM   #10
rdporterjr
I have the truck up on stands and the drive shaft out, so that's not gonna work right now. Thanks I appreciate it.
I have just rebuilt the harness so it should be good. But I should do it as soon as I get another hand. That is one of my major challenges right now.
Old 07-04-2007, 01:07 AM   #11
RACINJASON22
GEARHEAD
RACINJASON22's Avatar
Man talk about bad luck on a dream truck wish I were closer as well as some of the other guys on here.
Can you try jumping the starter to see if it engages,
The older 283 does not have a center crank bolt. but if the clutch is screwy make sure it is on those stands real good before you do this and I would even put a couple extra blocks under there just to be safe.
RJ22...
72 SWB 2WD MY PROJECT
72 LWB 4X4 FUTURE PROJECT
SUBSCRIBE HEREBOARD VENDORS HERE
NORWOOD MEET SURVIVOR!
RACINJASON22 is offline   Reply With Quote
Old 07-04-2007, 01:13 AM   #12
rdporterjr
RJ22...
Just bought a new starter and it works fine.
I ran into a 82 Camaro Z28 motor and auto trans that has caught my attention for 400 bones. I'm thinking about hitting up the finance dept. i.e. wife.
Old 07-04-2007, 01:15 AM   #13
RACINJASON22
GEARHEAD
I mean jump the starter while it's on the truck and cut out the middle man I.E. wirering.
What engine is in the 82 camaro for 400 dollars?
RJ22...
Old 07-04-2007, 01:29 AM   #14
rdporterjr
RJ22...
I was thinking of that about the time you sent the post. I'll try that in the morning. Thanks.
It's a 350. It runs and has HEI so thats a plus.
Old 07-04-2007, 01:43 AM   #15
RACINJASON22
GEARHEAD
If you do go that route I would still get every thing worked out on the 283 first just so you know.
Also if you go theat route do a search on how to change over the truck to HEI on how to change the power lead over from points to HEI. the original points power lead woill not cut it as power drop after the truck starts. Hei needs full 12 volt all the time.
There are some good write ups on here check out the FAQ's here they have alot of very good info to check out.
RJ22...
Old 07-04-2007, 01:47 AM   #16
rdporterjr
Thanks. I've been looking at these HEI conversion posts.
There is a lot of good stuff.
Old 07-04-2007, 09:52 PM   #17
rdporterjr
I ran a wire from the starter to the battery posts and the truck turned over. so it is not frozen. However It didn't start or even try to pop off.
I want to make sure that I have the coil hooked up right.
points style distributer w/ external coil (for now)
Yellow wire goes from starter "R" to "+" coil.
What happen to the "-" side of the coil?
Thanks,
Old 07-04-2007, 10:45 PM   #18
jhow66
jhow66's Avatar
Thanks,
"-" post will have a wire from dist. hooked to it. "+" post will have a wire from starter (yellow) and a resistor wire from switch. Turn switch on and check to see if you have power to coil. (yellow wire will have power only when engine is cranking).
Before you buy the '82 engine, run the #'s on it-could be a 305.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 07-04-2007, 10:54 PM   #19
krue
Designated A-hole!
krue's Avatar
The numbers will tell, you can't look at a small block and tell what it is otherwise (at least I can't).
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 07-04-2007, 11:34 PM   #20
drman929
drman929's Avatar
I didn't even mess with the old points. I bought a new $45 HEI on ebay and my 350 fired right up after 23 years of barn life.
drman929 is offline   Reply With Quote
Old 07-04-2007, 11:39 PM   #21
WinDancer
The Original HotRod KnifeMaker
WinDancer's Avatar
Hey, RD, don't lose heart or hope. Keep your eye on the result you are after- that gorgeous truck in front of your place with the keys in your pocket. Mine was down this last time for a little over six months. Tonight it is sitting on the lawn below the house, freshly washed and greatly admired.
One thing you need to get used to with these old trucks is that there as always al least one more thing to do- they are never finished and 100%.
I wouldn't trade mine for anything else.
My wife likes it as well as I do
Welcome from scenic Tenino [south of Olympia about 20 minutes]!
Dave
69 GMC SWB 2WD 454 Turbo 400
WinDancer is offline   Reply With Quote
Old 07-06-2007, 12:03 PM   #22
rdporterjr
Thanks WinDancer,
I was loosing hope but I just put my head down and got dirty.
So now it cranks! But it doesn’t start yet. I got the wiring straight. I figured out that the wiring harness that I picked up at the pull a part was from an auto, so the neutral safety switch wasn't hooked up. I just wired those together. My coil was also toast. Instead of buying a new one I just grabbed an HEI from another truck and put it on. The next problem is that my plug wires wont match up to it.
Tonight I'm going to gap my plugs and get new wires. Hopefully this rig will fire up.
Wish me luck...
'69 SS
i.e. '69 Chevy Short bed Step side
Old 07-08-2007, 01:21 AM   #23
rdporterjr
She Cranks, She Runs, She backfires...
It's backfiring through the carb. I've searched the forum for backfiring issues, most are timing or exhaust related. Is there anything else I should look for?
'69 SS
Old 07-08-2007, 01:33 AM   #24
wibilly
wibilly's Avatar
sounds like you may have some sticky valves
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 07-08-2007, 01:43 AM   #25
rdporterjr
Yah know, that wouldn't surprise me. I hear my truck had been sitting for awhile before I got a hold of it.
'69 SS
