Old 07-05-2007, 05:54 PM   #1
lks dcvn
lks dcvn's Avatar
removing wipers
Was going to do some cowl cleaning on the 69 and couldn't remove the wipers - I didn't see any tabs to press up to remove them - if they (the tabs) are gone and I screwed?
Any and all help appreciated...
Tom
lks dcvn is offline   Reply With Quote
Old 07-05-2007, 06:49 PM   #2
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Re: removing wipers
They should just "pop" off. Try putting a towel and a small block of wood on the cowl and use a pry bar to gently lift them off. I'm not sure if any PB Blaster or similar product might give you a little more release.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 07-05-2007, 07:09 PM   #3
jcfoote60
Active Member
jcfoote60's Avatar
Re: removing wipers
they look normal to me, wiper removal can be a PITA, but make sure and do what bouncy suggests to protect your paint. I use a smaller flat blade screw driver and work the tab....hold your mouth just right and walla! never tried the block of wood trick
jcfoote60 is offline   Reply With Quote
Old 07-05-2007, 08:36 PM   #4
Jimmy72custom
Jimmy72custom's Avatar
Re: removing wipers
Or get one of these! It works very well. Hook it and pull the arm off. I just wish I could remember where I bought it. To long a go.
Jimmy72custom is offline   Reply With Quote
Old 07-06-2007, 12:55 AM   #5
abtsj
abtsj's Avatar
Re: removing wipers
I was always told to lift wiper then pry. I'm pretty sure that's how the tool works to.
abtsj is offline   Reply With Quote
Old 07-06-2007, 11:32 AM   #6
lks dcvn
lks dcvn's Avatar
Smile Re: removing wipers
got them off - FINALLY - didn't want to break anything...what a PITA.
there was a whole host of pine needles in there - they are all gone now - will have to use a screen in there when I put this back together later today...
Thanks everybody for the help...
Old 07-06-2007, 07:44 PM   #7
Jimmy72custom
Re: removing wipers
I put screen in mine, but It cut the air flow to the vents so much I took it out. The tool allows you to pull up the arm evenly, works slick.
Old 07-06-2007, 08:10 PM   #8
RED72blazer
urban fourwheelin
RED72blazer's Avatar
Re: removing wipers
I have that tool, Bought it from Snap-on. Works great.
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage.
RED72blazer is offline   Reply With Quote
