Old 07-15-2007, 05:35 PM   #1
BabyBlue
The Peacemaker
BabyBlue's Avatar
Question on Matting engine & trans
Okay, sooooo exnay the matting problem...that I can take care of now, but now the problem is my new TCI flexplate doesn't fit my original torque converter as far as the bolt pattern goes. I'm guessing I finally screwed myself over, because I don't think I can put a torque converter in while the blazer is on the ground let alone what size to get and so on? Is the remedy taking the blazer to a shop, or is this something I should extend my engine startup date for?
1978 Chevy 2wd Stepside
aka "Audrey"
Cordova brown with mandarin guts
79k original miles & being restored
1979 Chevy 2wd Short Wide
aka "Emma-Jayne"
2019 Chevy Tahoe LT
Previous rides:
-2002 Firehawk T/A, 2006 Trailblazer SS AWD, 2014 GMC Sierra RCSB, 1971 2wd Blazer, 1996 SNB, 1997 2dr 2wd Yukon, 2001 Silverado RCSB, 2011 Silverado Z71 4x4, 1982 2wd Blazer, 1997 2dr Tahoe, 1970 Chevelle SS, 1972 2wd Blazer, 1986 Silverado Stepside, 1995 S-10, 1985 Silverado SWB.
BabyBlue is offline   Reply With Quote
Old 07-15-2007, 09:38 PM   #2
larry may
Re: Question on Matting engine & trans
Do what ever is needed to get the engine and trani evenly spaced all the way around then push them together. Jack it . shove it what ever it takes.
The biggest problem people have, is other people
Thou shalt be cool and not hassle
Be a site supporter.
The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2
larry may is offline   Reply With Quote
Old 07-16-2007, 10:01 AM   #3
MI2CHEVYS
MI2CHEVYS's Avatar
Like he said "What ever it takes"
Just make sure that the Guide Pins are lined up on each side of the trans.
Oh yea and from experience double check and make sure your torque converter is in all the way, some times they come out a little when you seperate engine from trans. Then you start thinking you have trans problems that really sucks.
GOOD LUCK !
MI2CHEVYS is offline   Reply With Quote
