Old 04-27-2002, 01:32 PM   #1
mooneyes
mooneyes's Avatar
Post gettin ignition out w/o keys???????
truck came with no keys, bought new keys and tumbler......cant turn key to accesories cause i have no key.....any ideas on how to get tumbler out????????
70 short step from vegas woo hoo !!!Ken Lyons Slippery Rock PA yahoo messenger:mooneyes4b "things always look different from higher up" Clint Eastwood (fist full of dollars)
Ken Lyons, Slippery rock pa
68 short step 327 t10 4 gear
72 2wd blazer project
70 lwb 305/700r driver
78 caprice project
02 cavalier D.D ( hate it!!)
mooneyes is offline   Reply With Quote
Old 04-27-2002, 02:02 PM   #2
pierce
pierce's Avatar
Post
I drilled one out from underneith the dash then right through the front, it eventually came out. Unhook the wires first.
72 Chevy Blazer
69 GMC Longhorn
37 Chevy Coupe
pics at http://home.fuse.net/pierce
Cincinnati, OH
69 GMC 1 Ton Longhorn
37 Chevy Coupe
pierce is offline   Reply With Quote
Old 04-27-2002, 02:14 PM   #3
mooneyes
mooneyes's Avatar
Post
i have the ing. switch out i just need to replace the tumbler
78 caprice project
Old 04-27-2002, 02:27 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
My GMC came without keys too.
I had shoved a small screw driver in mine and d!cked with it for a while. I was finally able to twist it counter clockwise enough for the allen wrench into the hole trick.
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite.
If you need a pic posted, E-mail me at longhornmail@yahoo.com
Andy, in Columbus Ohio
Old 04-27-2002, 02:32 PM   #5
mooneyes
mooneyes's Avatar
Post
ok ill go d*ck with it for awhile...or maybe ill have the wife do it she's better with them things...LOL ..thanks
78 caprice project
Old 04-27-2002, 05:41 PM   #6
70jimmy4x4
Post
How about this....
Pay shipping and I will send you a "new" used
ignition switch !
'70 jimmy 4x4
'98 chevy zr2 (the misses' transpo)
'65 stang
'81 shovelhead
contact me: email--showme219@aol.com
'70 jimmy 4x4
'65 stang
'81 shovelhead
'99 Dodge Ram 1500
70jimmy4x4 is offline   Reply With Quote
Old 04-27-2002, 05:45 PM   #7
Fast68Chevy
Fast68Chevy's Avatar
Post
sometimes you can actually use a key out of some other older GM vehicle and the teeth are cut close enough ot the same that t wil work with the switch, have had it happen a few times, i saved all keys from all vehicvles ive scrapped over the years, they have saved my *ss a few times, had no key for the 68 panel when i got it and i found a key here in my collection that worked in it
my stapdad's ign switch accepts my brother's 92 S-10 door key, so,, you just never know,,
good luck
Randy- Lincoln, IL
r68c30@hotmail.com 2177353230
-71 C-10 350/CH465/3.07, assemble it, yeah right, that'll happen in this world,(not)
-84 Z28 Camaro 5.0L 700R4, 3.73, beater, paid way too much for it like an idiot,,
-84 Firebird SE 2.8L T-5, rod knocking, dammit,,
-82 Firebird 350 4bolt (TBL)/TH350, not running, dammit...
buy/sell/hoard/trade most any GM vehicle parts of any kind
-parting out: '81 Cutlass Supreme Brougham
*Paint is overrated
© RSS Enterprises 2000
Fast68Chevy is offline   Reply With Quote
Old 04-27-2002, 08:13 PM   #8
mooneyes
mooneyes's Avatar
Post
well thanks if all else fails i'll take ya up on that offer..screw driver didnt work for me.. tommorow i'll try some gm keys..thanks guys!!!
78 caprice project
Old 04-27-2002, 08:45 PM   #9
Fast68Chevy
Post
borrow anyones GM keys that you can, you never know, you may find one that works, hehe
Randy- Lincoln, IL
randy@ccaonline.com 2177353230
*Paint is overrated
Old 04-28-2002, 04:29 AM   #10
TERRYP
GYRO GEARLOOSE
TERRYP's Avatar
Post
Some 40 years ago, while in high school, I acquired a full set of GM keys, believe they were ordered via mail order. There were about 85 keys, and one or more of them would open up any gm car. I passed them on to an undergrad when I graduated.
Everett, Washington
57 3/4 rat, 235, 3spd
66 C-10 Panel, SWB. 350 from '68, 200R4 tranny, 3.07 rear ratio, restoring
68 C10 LWB 350 4spd, 4.56 rear dump runner
82 Camaro, 305, THM-200-R4
84 Monte Carlo 305 TH350, land tuna
85 Tercel SW, snow runner
[This message has been edited by TERRYP (edited April 28, 2002).]
Nevada City, CA
Everett, Washington
DISGRACED OUTLAW MEMBER OF THE DRUM BRAKE CLUB
TERRYP is offline   Reply With Quote
Old 04-29-2002, 06:12 AM   #11
Ed ke6bnl
Post
We thought we would do it the dright way and the lock smith pulled out a set for the 70 chevy 250 keys after about 45 min not one key worked. The next step is to clean out the lock and do it again. I told his to forget it I would drill it out. We drilled it out a little at a time with about a 3/8 drill when the key part turned with a screw driver we followed the proceedure with the paperclip an remove and changed it all out. Good luck Ed ke6bnl
Ed ke6bnl
Agua Dulce
70 S.E. Los Angeles
70 Chevy short bed
Sorry 50 F1 pu
Sorry 63 Ford Econoline pu
Ed ke6bnl
Agua Dulce
70 S.E. Los Angeles
70 Chevy short bed
1948 F3 ford pu
1949 F1 stock V8 flathead 3 on floor
1950 F1 pu street rod
1948 F6 Ford Dually/350sbc no bed stock trans&rear
1972 El Camino 4" chop
1953 Chevy 3100 2b daily driver
1970 SB 4X4 400ci 6in lift
Ed ke6bnl is offline   Reply With Quote
Old 04-29-2002, 07:24 AM   #12
wbmoore
Exclamation
I took out the door lock, took it to a lock smith, he got the code off it and made a key which worked for it. I took it home and started my truck. Total cost:$12.75
1967 GMC 3500 lwb dump flatbed project
1969 GMC 2500
1979 GMC 7000 fire crew truck w/water pumps
1982 C/30 Cummins NV5600 Crew Cab project
wbmoore is offline   Reply With Quote
Old 04-29-2002, 06:49 PM   #13
Longhorn Man
Post
Woah, I forgot about the codes...if you remove the door lock (asuming it is the same like it should be) you can go to the dealer with it and they will cut you one for a couple bucks. I did this about 10 years ago with one of my Monzas.
Old 04-29-2002, 07:50 PM   #14
mooneyes
mooneyes's Avatar
Post
thanks guys...went to my buddy's house today and he was lookin through his parts trucks..(about 10 of them..)..and what luck!!!!! he had one with the tumbler already out...i'll have to remember the code thing...thanks again!!!!!
78 caprice project
Old 04-30-2002, 05:23 AM   #15
TERRYP
GYRO GEARLOOSE
TERRYP's Avatar
Post
If you have a locking glove box, the key number is on it.
Nevada City, CA
Everett, Washington
