Got 20's????
Funniest thing happened.
My brake booster has always been bad. Brakes were never very good. Finally they got to the point where I had to stomp on the pedal to slow down just a little. So I went and bought a new booster. Brakes are sweet now, and my lockup converter is working in my 700R4. I have done everything I could think of to get the lockup to work and it never did. I finally gave up on it and all of a sudden it works because I got my vacuum back. I pulled 14.16 mpg today going 65 for 72 miles and 75 for 32 miles bucking a strong wind. I have to switch from manifold to port vacuum though I think.
99 Silverado Ex-Cab 2wd, Bagged&WhippleCharged 02 Sierra Ex-Cab 4wd 2500 HD The 72 went down the road. |
#2 | |
CCRider
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
Got 20's????
vacuum switch for the lockup converter. It locks up immediately when it hits 4th gear and doesn't lockup in 3rd, so I think the vacuum might be screwing it up.
Did you add a stock unit or from a later model Chevy? Are you running discs? Sounds like you can actually run and stop now; Definately always good to stop.
Brandon ![]() |
What did the new booster cost you?
69 SWB LT1/4L60E www.classicplace.com |
14.1 @ 96MPH
If you have the 4th gear pressure switch wired in, you won't get it to lock up anywhere other than 4th gear.
Project1970 - LS1 Swap Complete! ![]() |
Yep if the booster is leaking bad you will have a huge vacuum leak. Causes bad idol and can make some engines run so lean that you will burn valves, destroy pistons etc.
Rod Childers '71 C10 Stepside |
