Old 07-25-2007, 04:11 PM   #1
ADBob
Transmission advice
Thinking of changing the plan for my 1950 Chevy 3100. Was going to put a 261 and T-5 in but am now considering a SBC for the performance, price and availability of parts. The truck will be a weekend and evening cruiser.
If I go with a carbureted 350, what auto transmission do you recommend? I was thinking a TH350 (cheap and easy to install) or a 700R4 for the OD. I have no experience with the 700R4 so I don't know how difficult the installation is or if a computer is required. The rear ratio isn't an issue as I still have to find a new rear end for the truck.
Thanks.
ADBob is offline   Reply With Quote
Old 07-25-2007, 04:40 PM   #2
robin58
Re: Transmission advice
700R4 is not computer controlled but depending on the year the speedo is either cable or electronic I believe.
robin58 is offline   Reply With Quote
Old 07-25-2007, 04:48 PM   #3
bigmike71
bigmike
bigmike71's Avatar
For a cruiser I would say to go w/ the 700R4. Gas prices arent going down and you don't want to pass everything but the gas station. I am currently building a 280-300 hp 350 and will be going w/ 700 for the OD, also a lower first gear. I will be going w/ 373 gears so I can still do the occasional burn out !!OCCASIONALLY!! (really for a more aggressive take off)The 350 will be cheaper to build but will run more rpm's on the highway. The 350 will probably be a stronger tranny for the lead footed driver.....just my 2 cents
bigmike71 is offline   Reply With Quote
Old 07-26-2007, 11:09 PM   #4
cajundragger
700R4 is far suprior to the TH350. I say 700R4 all the way. I know the later model ones in vette's(92ish) have electronic speedo's...
cajundragger is offline   Reply With Quote
Old 07-27-2007, 06:41 PM   #5
Igotachevyor2
Apache Club
Igotachevyor2's Avatar
DEFINATELY GO WITH THE 700R4 it can handle most all the hp and torque a masaged small block can dish out.
58 CHEVY APACHE I 74 CHEVY C-10 I 78 K-10 donor truck I 89 SONOMA
My Trucks Apache Sitting Idle MySpace
Project Dad's Truck (74 C-10 to K-10 conversion)
Igotachevyor2 is offline   Reply With Quote
Old 07-27-2007, 10:02 PM   #6
55ChevyPU
55ChevyPU's Avatar
Ive got a th400 in my truck, not having that overdrive sucks. Go with the 700r4 so you can drive around on the freeway.
55ChevyPU is offline   Reply With Quote
Old 07-28-2007, 12:12 AM   #7
ADBob
Thanks for all the advice. The '69 GMC I built and sold 10 years ago had a TH400, great truck but it really chugged the gas on the highway. Did a bit more research and the 700R4 looks like an easy install and shouldn't be too difficult to rebuild.
Old 07-28-2007, 12:47 AM   #8
Smurfer643
Get some help with your kickdown cable or you'll eat your transmission in 100 miles!
1971 Chevy Half Ton Long Box 2WD
Puyallup, Washington
Smurfer643 is offline   Reply With Quote
Old 08-06-2007, 02:35 AM   #9
bull1kevin
the 700r4 will not hold up to a stout small block! I've been building drag raceing cars for years. 400-450 hp max on a 700r4 without spending big coin to make it survive.
bull1kevin is offline   Reply With Quote
