![]() Join Date: Sep 2001
Loud & WIERD popping noise in front end-->mystery solved.
A few months ago I posted a question about a strange popping noise in my front-end that only happened when I pulled away from curbs, or sometimes just stomped the gas. It never seemed to happen when I hit a chug-hole, or mashed the brakes, or when I went over speed bumps, which is usually when I would think ball joints would be bad. It had me baffled, and it sounded VIOLENT, so I figured I would find the reason when I did my front-end rebuild, which I started Labor Day weekend, so....
I found it. ![]() Luckily my lower control arm hasn't been ovaled out as well by all of this movement, which surprised me. All of the wear was absorbed by the cap. Just an FYI for anyone who hears a loud pop from their front and it doesn't seem like it's a ball joint... Happy Trails.
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
67-72 Addict!
Cobalt, I've had a few of these thumps lately. Thanks
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
