Old 09-23-2002, 03:17 PM   #1
jmil1974
Ain't we cute?
jmil1974's Avatar
Do I have a posi?
I am taking my drums off the back and I spun the axle and both axles turned. Does this mean 100% for sure that I have a posi?
Thanks!
Jason
69 C10 2WD LWB Fleet 350/350 power front disc conversion (6 lug disc kit from gmcpauls) and new engine, PS, A/C, fresh fluids, SHE DRIVES!
FOR SALE $3900
jmil1974 is offline   Reply With Quote
Old 09-23-2002, 03:27 PM   #2
Gene
Gene's Avatar
No but what better excuse to change that differential oil than to check and see if you have a posi-trac...If you see a bunch of springs and clutches in there you got one! If you just see gears you aint got one..
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Gene is offline   Reply With Quote
Old 09-23-2002, 03:27 PM   #3
Michael A. K. G
No. It may mean that the turning resistance for the rear driveshaft is less than that for the far axle shaft. But it's likely you do.
Put one rear wheel on the ground, and the transmission (or transfer case, if you have one) in neutral. Then turn the off-the-ground wheel by hand. If you can't, you have a functioning Posi. If you can, you have either an open diff or a worn out Posi. You can't tell an open diff from a worn out Posi without removing the diff cover and inspecting the diff.
Note that if you have a 4x4, you have to either put the transfer case in neutral or raise the FRONT wheels, too.
Michael A. K. G is offline   Reply With Quote
Old 09-23-2002, 03:27 PM   #4
67 C-10 LWB
67 C-10 LWB's Avatar
not 100% for sure
if you spin them and they both go the same direction then you very well could have a posi
but if you spin them and they turn opposite ways you either have an open rear, or a worn out posi
hope this helps...
I heard the only sure way to know is to pull the cover
Ean
1999 Silverado Ext Cab Short Box Z71
2006 Trailblazer (wifes)
2 '04 KFX400's
My Site
67 C-10 LWB is offline   Reply With Quote
Old 09-23-2002, 07:08 PM   #5
jmil1974
Ain't we cute?
jmil1974's Avatar
Thanks, guys!!
FOR SALE $3900
