09-23-2002, 04:32 PM | #1 |
Slowly getting CRSS...
1/2 ton stock coil spring length?
Anybody have measurements of the length of stock 1/2 ton front coil springs +- the fatigue from old age?
I think mine are front drop springs.
-Nic Lutz, Fl My Team Website The Heavy Chevy Website ------------------
There is No replacement for Displacement... "If everything seems under control, you're just not going fast enough." - Mario Andretti |
09-23-2002, 05:32 PM | #2 |
I can take measurements of my truck if you want.
(I don't have no big old stinkin' rat sitting under my hood though!):p
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles. TREASURER, Drum Brake Club. |
09-23-2002, 06:37 PM | #3 |
Are you talking about springs that are not installed, or compressed?
69 SWB LT1/4L60E www.classicplace.com |
09-23-2002, 07:01 PM | #4 |
yes, uninstalled springs that are not compressed
09-23-2002, 07:23 PM | #5 |
My old ones are about 14-1/4". I purchased some 1" drop ones that were much more than 1" shorter when they were uncompressed. I don't know how they will sit with all the weight on them.
09-23-2002, 09:33 PM | #6 |
anybody else have any measurements just so as i can get a general figure on the length?
09-24-2002, 08:40 AM | #7 |
Have you installed the new springs yet? I have not installed mine yet but the paperwork with them says not to be alarmed if they are shorter than the ones you take out. They are still designed to give the same ride height.
FOUNDING MEMBER OF THE DRUM BRAKE CLUB Second Owner 70 C-10 Second Owner 93 GMC C1500 Third Owner 99 C2500 Crew Cab Short Bed |
09-24-2002, 04:02 PM | #8 |
i havent taken mine out yet the reason i wanted to know though was im not sure if i have lowered springs already. The reason i ned to find out is that the top control arm ont he drivers side is fully spaced out and that wheel still has 1.0 camber. So i need to make sure i have the stock setup to see whats up.
