Formerly yellow72custom
Timing Tape
I want to be able to see how many degrees of timing my truck has when the vaccum advance is running. I don't have a dial-back timing light, and the stock timing tab only goes to 14 or so. I have heard of using timing tape on the harmonic balancer to find this out. How does the timing tape work, and where can i get it?
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
drag racer
Timing tape is a piece of tape that has graduation marks on it for the full 360 degrees of your balancer. You have to make sure that you get the appropriate one for your balancer. Clean the balancer, match up the TDC on the tape with your 0 degree mark, and wrap it around the balancer.
Jegs lists 4 different timing tapes 6 inch, 6.75 inch, 7 inch, and 8 inch. $6 for each of them. 67chevelle
Current rides: 01 GMC 2500 SB HD CC 4x4 8.1 allison 67 Chevelle drag car 516 CI BBC,TH400 9.777 @ 138.4 mph 1970 C10 2WD PU being rebuilt 1967 El Camino 502, TH400 ( wife's drag car) Jr. Dragster 5 hp B&S for the kids |
i find it best to use the tape to mark the balancer..I use white out.. my experience is that the tape will not stay on..unless you clean it real well and use some killer adhesive
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
