Old 09-23-2002, 06:17 PM   #1
RodC
RodC's Avatar
How do you Remove all those bed bolts!?!?
I'm going to replace my wood bed. How do you get all those bolts out. They are all square head and I dont think they are gona turn. I wish I had a set of tourches but I dont.
Can the wood be removed and the use a recip saw to cut the bolts?
I dont think I can grind all the tops off, that would take forever.
Rod Childers
'71 C10 Stepside
RodC is offline   Reply With Quote
Old 09-23-2002, 06:38 PM   #2
bowtie
bowtie's Avatar
torch'em
I borrowed a torch, easiest and quickest way.
Fast might still have one for sale.
~70 GMCprostreet swb 396/700r NOS 575 hp "the Brick"
~72 chev swb w/68 front clip "GM Millenium corvette yellow"
I use and accept Paypal
bowtie is offline   Reply With Quote
Old 09-23-2002, 06:39 PM   #3
COBALT
COBALT's Avatar
Do you have a set of heavy-duty steel nips (sort of like perpendicular bolt cutters)? Those'll work.
I just got a set of vice grips on the head against a block of wood, and turned the nut until the stud broke with a pipe wrench. That worked well only because my bed is in HURTIN' shape. The rest you can cut off with a die grinder from underneath, and the hard-to-get ones you'll just have to grind off the heads.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 09-23-2002, 06:43 PM   #4
palallin
You may be able to bash out a lot of the wood and use standard bolt cutters on many of them. I may have to do that.
Be careful using a smoke wrench: that wood may ignite if very old/dry. . . .
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
Old 09-23-2002, 07:21 PM   #5
Chevy Punk
Has anyone tried unbolting them or will they for sure break. It doesnt seem like it would be very hard with air tools.
Chevy Punk is offline   Reply With Quote
Old 09-23-2002, 07:56 PM   #6
special70gmc
special70gmc's Avatar
i used a saws all got under em and cut em off
1986 c-10 swb 5/7 drop 20'' coys
1958 belair 2door
special70gmc is offline   Reply With Quote
Old 09-23-2002, 11:55 PM   #7
palallin
Assuming the square holes hold up to the pounding. Otherwise, it'll be Spin City.
Old 09-24-2002, 12:01 AM   #8
Southpa
Southpa's Avatar
The first time I went at it I wasn't thinking. I tried to unscrew them and naturally, they were all rusted and fused and started spinning. So there I was ripping out the old wood and taking advantage of the new gaps with hacksaw, prybar, boltcutter, chisel, grinder etc. Of course, after I realized all this hardware is expendable I came up with a great idea. Turn the bolts the other way and snap off as many as you can.
1970 GMC 1500 Custom
Original 350/TH350
Victoria, BC, Canada
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
Old 09-24-2002, 12:44 AM   #9
ChopTop
thank the good lord for the bluewrench! Sometimes your local welding supply will rent you a small outfit, backpack type. cost me 50 bucks once.
ChopTop is offline   Reply With Quote
Old 09-24-2002, 01:00 AM   #10
Paul Clark
More uncharted territory for me here, 'cause I don't know squat about bolts for a wooden bed.
However, when my carriage bolts (that's pretty much what they are) were stripped and spinning, I used a cut-off wheel to cut a groove in the top of them. Had a buddy hold a screw driver in the top while I used an air ratchet underneath.
Paul Clark is offline   Reply With Quote
