Old 07-29-2007, 12:22 AM   #1
ClassicAutoResto
Rust Buster
ClassicAutoResto's Avatar
1960 702 ci V12
How about one of these for your truck? Yes they were made for 60-66 chevy (large) trucks. This one would flip my cherry picker real quick.
http://www.6066gmcguy.org/Jolly-702v12.htm
or this one;
http://www.6066gmcguy.org/TwinSix.htm
jerry
p.s. give anyone ideas for a mid engine 60-66 suburban?
ClassicAutoResto is offline   Reply With Quote
Old 07-29-2007, 07:29 AM   #2
60ratrod
yes, i do
60ratrod's Avatar
Re: 1960 702 ci V12
makes homer simpson drooly noise........ me likey!!! would deffinatly be a sight to see at a carshow in one of our style trucks
60ratrod is offline   Reply With Quote
Old 07-29-2007, 10:00 AM   #3
hewlett2002000
hewlett2002000's Avatar
Re: 1960 702 ci V12
omg i would love to get my hands on one of those for my truck. that would be bad ass. im going to eaither go with a caddy 500 or a ls1. im undecided but leaning tword the ls1.
Respect:
1. A feeling of appreciative, often deferential regard; esteem.
2. The state of being regarded with honor or esteem.
3. Willingness to show consideration or appreciation.
When you fail to show consideration to others values you are showing disrespect.
hewlett2002000 is offline   Reply With Quote
Old 07-29-2007, 10:12 AM   #4
krue
Designated A-hole!
krue's Avatar
Re: 1960 702 ci V12
Good reading there.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 07-29-2007, 10:33 AM   #5
ClassicAutoResto
Rust Buster
Re: 1960 702 ci V12
With that engine, I wonder if you would need to go with the front springs for an A/C truck? LOL
Jerry
Old 07-29-2007, 10:43 AM   #6
mbgmike
Re: 1960 702 ci V12
Yeah
I remember laying in bed at night as a kid and hearing the Old Wilson Freight down the road leaving the Terminal Late at night. They Had a Fleet of those trucks with those motors. They have there own unique sound. I kind of miss hearing them. I would love to have one.
mbgmike is offline   Reply With Quote
Old 07-29-2007, 10:45 AM   #7
mbgmike
Re: 1960 702 ci V12
or this one;
jerry
They used them in stationary compressors also. Like in pipeline/oil field.
Old 07-29-2007, 10:46 AM   #8
ClassicAutoResto
Rust Buster
Re: 1960 702 ci V12
I would love to hear one run. Here is another forum discussion I found on this engine.
The 702 V12 was a gas engine,never was a diesel version of it. Notice JD's picture has two natural gas/propane carbs. The sparkplugs are on top of the heads between the valve covers and intake manifold. In later years,the 702 V12 was replaced by the 637 V8.
Jon Hagen
12-19-2006 17:38:10
69.26.30.29
519260
Re: speaking of 2 stroke diesels in reply to Jon Hagen, 12-19-2006 17:20:21
Whups,I read JD's post again. The 702 V12 Was a factory built truck engine, built with a lot of V6 parts. The block,crankshaft and camshaft were one piece V12 units,exclusive to the V12, with 4 V6 351 heads and exhaust manifolds. It used 2 V6 351 intake manifold and carb assys. It had an odd distributor at the rear of the block with the dual points under a metal cover and two 6 cyl distributor heads,rotors,caps to fire all twelve cylinders. The 637 V8 was more powerfull and much more durable.
The downfall of the 702 V12 was that looong spindly crankshaft. Most died from a broken crankshaft in truck use.
Detroit Diesel,atleast in the 149 series,and I think smaller series,assembled V12 and V16 engines by bolting 2 V6 or V8 blocks together. They a special long alignment shaft to fit the main bores of both blocks to keep the mains in alignment while bolting the blocks together.
Old 07-29-2007, 11:14 AM   #9
mbgmike
Re: 1960 702 ci V12
Here is one of those bad boys. This is how dirty they usually looked too
Some of theirs were factory and some of theirs were stretched and added on. the hoods were too short and they scabbed a section on kind of hap hazard. Most had two little wimpy exhaust pipes up the back .The picture is really of the 8V-71NE Powered truck. I wish I had a 12 v pic. They had the scabbed hood that looked even stranger. Looked like they had done it themselves.
Old 08-22-2007, 09:48 PM   #10
Tomsriv
Tomsriv's Avatar
Re: 1960 702 ci V12
Originally Posted by mbgmike View Post
Yeah
Ask and you shall receive. I did a youtube search on "702 GMC" http://www.youtube.com/results?searc...&search=Search
Tomsriv is offline   Reply With Quote
Old 08-22-2007, 11:35 PM   #11
slepysal
slepysal's Avatar
Re: 1960 702 ci V12
wow and only wow!!!
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 08-24-2007, 11:08 PM   #12
ClassicAutoResto
Rust Buster
Re: 1960 702 ci V12
Thanks for the link Tomsriv.....anyone have one to install?
Old 08-25-2007, 01:09 AM   #13
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: 1960 702 ci V12
did y'all get a look at this project?
check it out here: www.blastolene.com/B702.html
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 08-25-2007, 02:09 AM   #14
Stepside65
Still Truckless!
Stepside65's Avatar
Re: 1960 702 ci V12
Hadn't seen it but is definitely very cool.
~James
Truckless
2009 Hyundai Sonata<~~Wife's sedanomatic
1997 Nissan Pickup Father-in-law's tonka toy I am forced to drive
Founder of The 60-66 Club
Tutor Et Ultor
Stepside65 is offline   Reply With Quote
Old 08-25-2007, 02:38 AM   #15
Dingfodgy
Lemme show you something!!
Dingfodgy's Avatar
Re: 1960 702 ci V12
I'll agree that the GMC factory beast is an impressive piece of nostalgia, but if you wanna s@*t purple twinkies....check this out!
http://www.falconerengines.com/prod04.htm
There's an audio clip of this thing that is just effin' ear-candy. It sounds like a swarm of pissed off bees- straight out of hell itself!
'67 CST-10 LWB ("Crusty") SOLD
'67 GMC SWB ("Murdock")
2000 K1500 Suburban ("Betty")
'95 BMW 325i ("Joy")
Dingfodgy is offline   Reply With Quote
Old 08-25-2007, 11:25 PM   #16
ClassicAutoResto
Rust Buster
Re: 1960 702 ci V12
WELL F.M.R. ........That's bad!
Old 08-26-2007, 12:37 AM   #17
Woogeroo
Re: 1960 702 ci V12
Jolly is good people... that is THE place to go if you have a 60-66 GMC truck.
-W
Woogeroo is offline   Reply With Quote
Old 08-26-2007, 12:44 AM   #18
hewlett2002000
Re: 1960 702 ci V12
well i have to be honest, if i knew where to find one i would shoehorn it into my truck just to be different!!!! and im serious. the only second thought i would have is gas mileage. anybody know what kind of mileage they get?
thanks,
John
Respect:
Old 08-26-2007, 12:46 AM   #19
hewlett2002000
Re: 1960 702 ci V12
what would really be cool is to extend the front end so you dident have to cut into the cab!!! lol that might be my next project(if this one ever gets finished). i shouldent think like that. MY PROJECT WILL GET FINISHED!!!!!!!
John
Respect:
Old 08-26-2007, 07:33 AM   #20
ClassicAutoResto
Rust Buster
Re: 1960 702 ci V12
It would be easier to cut into the cab and use a van engine cover though?
Old 08-26-2007, 08:31 AM   #21
hewlett2002000
Re: 1960 702 ci V12
yea that would be easier, but why take the easy way out? lol the hard part is the fun part.... sometimes
John
Respect:
Old 08-26-2007, 03:11 PM   #22
gulfcoast66
64-66 CHEVY JUNKIE
gulfcoast66's Avatar
Re: 1960 702 ci V12
talk about big block, thats one bad mother... i would love2 just have a running one on blocks!!!!!!
1966 C-10 Fleetside LWB, 350 Lt1 4l60-E
2008 Silverado Crew Cab, 4.8 4l60-E
1998 GMC Yukon 4x4 L-31 Vortec, 4l60-E
2017 GMC Serra 4x4 5.3 Vortec, 4l60-E
Do It In A Chevrolet
gulfcoast66 is offline   Reply With Quote
Old 08-26-2007, 03:42 PM   #23
cst70rocket
Re: 1960 702 ci V12
This one may be for sale here in San Angelo,Tx.
cst70rocket is offline   Reply With Quote
