Old 08-01-2007, 11:42 PM   #1
ADBob
AD power steering or IFS
Another question related to putting a SBC and 700-R4 in my 1950 1/2 ton. I have read of problems using the typical power steering kit like CPP sells that mounts a newer box to the frame inside the wheelwell for these trucks. The stock box won't fit with a SBC. Is there a power steering kit that works well with the straight axle or should I just spend the extra to go IFS? Looking for a mild drop, maybe 3 inches or so from stock. Looking at the build threads I know these are really basic questions for this group but this is my first try at a truck this old and I want to do it right the first time.
Thanks,
Bob
ADBob is offline   Reply With Quote
Old 08-02-2007, 01:46 AM   #2
stevehsd
stevehsd's Avatar
Re: AD power steering or IFS
I say go with the MII and power steering!
51 3100 build thread http://67-72chevytrucks.com/vboard/s...light=stevehsd
77 FLH
stevehsd is offline   Reply With Quote
Old 08-02-2007, 11:05 AM   #3
pgf545
pgf545's Avatar
Bob, I would go with the MII and rack also. It is an easy swap. I did the one on my dad's truck and there are several others on here doing them also.
Bernie
52 Chevy Truck (Dad's)
http://67-72chevytrucks.com/vboard/s...d.php?t=206021
pgf545 is offline   Reply With Quote
Old 08-02-2007, 01:37 PM   #4
robin58
I have a SBC, dropped axle and monoleafs and run an early 80's Saginaw P/S box in my 53 3100. I fabbed up my own mount but don't have any clearance issues. Nothing against a MII but I sure wouldn't spend $1,700 just because I didn't want to make an easily available cheap p/s box you can find at any junkyard work. Of course it really boils down to what you are looking to do and how much you want to spend. If you add up dropping an axle (or a new dropped axle), converting to disc brakes, upgrading the tierods, etc etc all up you get close to the cost of a MII anyways. The advantage is though you can do it over time and upgrade when cashflow allows. Personally I like the look of a nice dropped axle but obviously it won't handle like something with a more modern suspension on it.
There is a rack+pinion setup for a straight axle too: nolimit.net makes one but it's pricy.
robin58 is offline   Reply With Quote
Old 08-03-2007, 10:57 AM   #5
ADBob
Thanks. The problems I've heard with adapting power steering to the straight axle are bump steer, rubbing on right turns and the frame flexing too much. Sounds like you don't have any of them.
Old 08-03-2007, 11:18 AM   #6
robin58
You can avoid the bumpsteer issues by making sure the pitman arm and draglink are all set up right. If at stock height, what CPP provides works well. If lowered, it'll take some thinking and adjusting but when you look at how it's all meant to work, it becomes pretty apparent what you need to do. I had to put my p/s box higher and I set it forward more making sure the draglink was as close to parallel to the leafsprings as possible (pretty close to horizontal on mine with monoleafs). Just spend some time visualizing what moves when the front wheels hit an obstruction/pothole/bump.
Old 08-04-2007, 12:26 PM   #7
55dude
55dude's Avatar
use a toyota 4x4 box from 79'-85', the ones with a solid front axle. thats what is going on my 54' burb. i have seen the one using a chevy truck box on the outside of the frame and they do rub, junk in my opinion.
55dude is offline   Reply With Quote
Old 08-05-2007, 09:14 PM   #8
drummin89
drummin89's Avatar
are you talking about these, im thinking of doing this too, these are both off a 83
Chris
52 Chevy 3600 (3/4 ton) 5 window pickup
-54 235 Inline 6 w/ Fuel Injection Conversion
-Clifford 2/4bbl Aluminum Intake and Headers
-1/2 ton front axle swap w/ 5lug disc brake kit
-CPP Power Steering Kit
Various pictures of my 52 Chevy 3600
drummin89 is offline   Reply With Quote
Old 08-07-2007, 03:21 PM   #9
ADBob
Prefer to stay with the straight axle for this project. Will just need to make the steering work if I go with a SBC. The other option is the 261 / T-5 combo I have in my garage and use the stock manual steering. Don't know if I would like the 261 for power and reliability though.
Bob
Old 08-09-2007, 11:57 PM   #10
55dude
55dude's Avatar
that is the box you want, the 4x4 79-85!
