Seņor Member
OK, as you may have noticed by my current line of questions in other posts, I'm fishing here...
As I understand it, the ignition switch in 67-72 trucks is the same one used way up into the 80's or so. Is this correct? And so the 73+ column-mounted ignition switch works the same way? That is, the switch makes contact on the starter wire and the truck fires up??? And so if I could figure out a way to meld a later-model steering column outer sleeve (the part behind the wheel that has the ignition switch in it) to a 67-72 column, then I'd have a workable setup??? What I'm trying to do is find a home for the ignition switch now that my dash is completely smooth. I am thinking about mounting it in a custom dash bezel but as ProSt68Trk and others have pointed out, having all this activity going on in the instrument bezel kind of defeats the purpose of smoothing the dash. I'm thinking that I could graft the protrusion from a 73+ column onto my existing culumn (it's pot metal... TIG weld it maybe? Heck, JB Weld it???) and snake the wires down through the center and tie them into the existing circuit. Then I get in and turn the column mount key and I'm off. Anyone got any input on this? Ideas? I'm nuts? Kenneth
faster, faster, faster
Won't the whole sleeve from a 73+ column work also instead of grafting in the protusion itself? Could save you some time. You could always make it a push button start with a toggle with a cool red flip up protector to turn the power on and then push a chrome button switch on the bezel to turn the starter. The power toggle could even be a two postion switch to accomodate for the ACC position. Add an alarm with an starter disable relay and it'll be just as safe as a keyed ignition switch. He!! if you have an aftermarket steering wheel you can buy the wireless center piece to control the starter. Take it off and inside with you at night and it won't ever start unless you press the button. I think I may be getting a little ahead of you though. Hope I gave ypu an idea though. Either way would be really cool.
I'm going to Law School, wanna debate? It's good practice. |
chevelito
my truck originally came as a push button start. All my dad had to do was turn the key and push the button. the key always kept falling out. That push button is gone now is replaced by a flip switch to run the reverse lights.
my new....those are some great ideas. jay
New deadline...when my son can drive. ![]() Aloha from Honolulu, HI |
Careful, they attack...
I've got a whole column from a 73 ish truck. It's a 4 spd type, so I hope you have a stick. But I would be willing to get rid of it cheap. I bought it off ebay cuz it came with a bellhousing I wanted. You could then just do the whole column at once.
Just an idea. good luck and take pics of whatever you decide. |
Perhaps you could put the ignition switch in the floor or a console (if you have buckets) like they do in SAABs. That would be a lot easier. Or, maybe you could have a small panel that could flip down from the bottom of the dash (although with the nest of wires that go on an ignition I don't know how well that would work).
OCB |
#6 | ||
Seņor Member
![]() Quote:
Kenneth
![]() Join Date: Aug 2001
Kenneth, I'm in the same boat as you with the ignition switch. What about having some secret security setup (ex. reed sw & magnet or the like...) that would draw up a relay then a small hidden switch under the dash could then be pressed to start. I mean who said that the ignition switch has to be a round piece of metal with a key? Heck, it could be anything. Possibly even relay operated via remote keyless entry on an aux channel. Your an old stereo/alarm guy...
Smooth68's Web Site WTB 64-66 project or frame/cab, SWB or LWB...I have the fever! Whatcha got?? '68 Short Step - Shaved Body, Soon Bagged - SOLD Driver-2004 GMC Z-71 Ext-cab |
#8 | |
Seņor Member
![]() Yeah, I'm starting to think about that solution a little harder. Something in me doesn't want to let go of the key concept (even though you can probably turn my ignition with a screwdriver... years ago I had a '68 C-10 that didn't have a key. I just made a duplicate of a buddy's '69 Dodge Charger key that started mine with no problem!). I don't think I'd want to go with a reed switch as they're too flaky. And I don't want to rely on RF in case the remote battery dies. But I could probably put together a "combination" lock of some sort-- either something simple like 'press A then B' switches or even a small button pad that required a key code (like Ford doors). Hmmm... keep the ideas coming. We're bound to come up with a good solution eventually! Kenneth
yep...I didn't want to bring it up earlier, but remember the car in Magnum PI - It had a cool credit card slot and small key pad. Hmmm....starting the 68 with a credit card....interesting
chevelito
yeah....you can use the credit card like a screw driver and turn a screw to turn on the truck.
![]() What about a push down button on the floor somewhere. (Well, a place that wouldnt get pressed while you were driving.) jay
GYRO GEARLOOSE
I use a standard column mounted switch that is operated by a 'T' handly in place of the manual throttle knob. works cleanly.
Nevada City, CA Everett, Washington 57 3/4 rat, 235, 3spd 66 C-10 Panel, SWB. 350 from '68, 200R4 tranny, 3.07 rear ratio, restoring 68 C10 LWB 350 4spd, 4.56 rear dump runner 82 Camaro, 305, THM-200-R4 84 Monte Carlo 305 TH350, land tuna 85 Tercel SW, snow runner DISGRACED OUTLAW MEMBER OF THE DRUM BRAKE CLUB |
#12 | |
Seņor Member
Thanks, Kenneth
#13 |
Seņor Member
How about something like this?
![]() It's programmable and ready to install. No engineering work required on my part ![]() I still have mounting location issues, but... maybe I could mount it in some kind of overhead console? OR??? Kenneth
#14 |
Not compact enough for me. Where would you put that thing anyway? A push button and a toggle. Since you got bags mount it on the plate for the bag toggles, and the button on the bottom right corner of the bezel. Nothing cooler than a well done push button start. But that is just my opinion.
#15 |
chevelito
if you are going that big, you might as well go for a retinal scanner also.
![]() I still like that idea of a toggle switch and a push button. Would anything happen if you left the toggle switch on? Probably not because the circuit does not close until the button is pressed. jay
#16 |
Leaving the toggle on would never be an issue since tht would be like leaving the key in the on psoition. You have to turn the toggle off to turn the engine off, and all the other electronics. The push button just engages the starter like the Start position on the stock ignition switch. The push button wouldn't be a on off button but a spring type momentary connection.
#17 |
Seņor Member
I may be making this unnecessarily difficult. What I need to do is come up with a solution using the existing lock cylinder. 1) I already have it, 2) it retains some small level of security, and 3) it is a "classic" component that can keep some original 'charm' of the truck (like the fact that I'm NOT doing power windows).
So... now, where to mount this thing??? Kenneth
#18 |
chevelito
QUOTE]Originally posted by my new 72
Leaving the toggle on would never be an issue since tht would be like leaving the key in the on psoition. You have to turn the toggle off to turn the engine off, and all the other electronics. The push button just engages the starter like the Start position on the stock ignition switch. The push button wouldn't be a on off button but a spring type momentary connection. [/QUOTE] I got it.... like those push buttons to check if a starter is working. Next question is what turns off when you turn off/ toggle the switch to off? ![]()
New deadline...when my son can drive. ![]() Aloha from Honolulu, HI Last edited by jay-dawg; 09-26-2002 at 02:32 PM. |
#19 |
Hey, I have a column installed in my truck that has a spot for a key switch. It has an Oldsmobile wheel on it but who knows if that is right. The column it self looks very close to the truck column, it is tilt and Auto. The column is actually blue in colour.
My wife's grandfather owned this truck prior to me and he was amazing at fixing things so who knows what it is out of. I can send you pictures next week if you would like. Heck I would even swap it with you if you have a truck column with tilt. let me know Trevor ![]()
Newby 69 GMC Also own 88 4X4 Toyota P/U 01 Toyota RAV 4 |
#20 |
XXL, my vote is a later model column w/wiper switch (or cruise control switch) on the turn signal stalk. Seems like it would be easier to make the column that has what you need fit than re-design the one you've got. I'm facing the same dilemma since my dash has no ign. switch or a/c controls. I'm gonna mount both of these & my air-ride controls along w/a set of mechanical guages for temp/oil psi in the factory center console where it's out of sight--but not reach.
#21 |
Seņor Member
Here's the concept behind the two switches...
The rocker, which is ON-OFF, simply enables the use of the pushbutton, which is (ON)-OFF.
