Old 08-09-2007, 09:32 AM   #1
lotussutol
questions about a tilt frontend on a 55-59
I am curious does anybody have a tech article on how to make a stock metal front body into a tilt body on the 55-59 trucks?
I have a general idea of how to set the spacing and start tacking the front body clip together and the general area to split the fenders. I have not however spent anytime thinking about how to do the front hinges.
Here is what else has me concerned. From the pics that I have seen with the camaro clip on the front the bumper is really close to the ground. Does the bumper tilt with the front or does it stay put?
Any pics and/or advice any of you have for tilt front ends would be great.
Thanks in advance!
Lotus
Current Rides/Projects
1955.5 Chevy shortbed truck
1952 Chevy Coupe Deluxe car
lotussutol is offline   Reply With Quote
Old 08-09-2007, 11:40 AM   #2
1-ton of fun
polishing a turd
1-ton of fun's Avatar
Re: questions about a tilt frontend on a 55-59
the bumper mounts to the frame, so it would stay put, otherwise it would not be mounted solid enough to work if needed
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512
53 buick special - straight 8 sled - blow through turbo
47 gmc - flatbed hot rod build
99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van'
1-ton of fun is offline   Reply With Quote
Old 08-09-2007, 11:53 AM   #3
lotussutol
cool. good to know that even with a tilt front the bumper mounts to the frame.
although with the camaro clip with the bumper being so low at most it is going to act as a ramp for what ever hits me.
Lotus
Old 08-10-2007, 03:14 AM   #4
MrSinister
MrSinister's Avatar
On the tilt front ends i've seen some tilt the bumper and some don't, defintely an up to you if you want to or not. If the bumper is goint to stay solid mounted you will need to address the front valance clearance as it sits sort of under the bumper and would hit it when you open the front up. One of the coolest tilts used hydraulic rams to push the entire front end out away from the cowl and then tilt up.
'56 Big window
350/700r4
9" rear w/disc
MrSinister is offline   Reply With Quote
Old 08-10-2007, 09:19 AM   #5
texascowboy593
texascowboy593's Avatar
Now I have no clue about fabbing a tilt unit up...but I do have a couple of pics of one way it was done...
"The rays of light thru the Shiner Bock bottle make me wanna turn the key and put down the throttle...and get lost down 35" - Jason Boland
www.YouTube.com/user/593Films - Watch My Videos!
1977 Silverado K10
2014 Dodge Durango (Wife-mobile)
2008 Dodge Ram Lone Star Edition (Daily driver)
texascowboy593 is offline   Reply With Quote
