Old 08-10-2007, 01:42 PM   #1
bull1kevin
help id motor
Just got a 50 model 3 window the inline looks to be a newer version looks like it has motor mount bosses on the side like a v8 (it's still mounted in the front) how do you id the motor? casting #'s? thanks for any help. has "cheverolet" stamped longways acrossed the valve cover with the filler in the front.
bull1kevin is offline   Reply With Quote
Old 08-10-2007, 02:20 PM   #2
lotussutol
Re: help id motor
If you can get the block or head casting number and you can tell what you have by going to this site and finding your number.
http://www.inliners.org/casting/numbers.html
on that page if you click CTRL + F (most web browsers) it will bring up a find window that you can type your number into and then click find.
What I have found a lot of times is the cast number to be worn down and or so grimy that you mistake a number for something else. best bet is to then find one that is close and then go back to the block or head and re-look at it to compare.
hope this helps.
Lotus
Current Rides/Projects
1955.5 Chevy shortbed truck
1952 Chevy Coupe Deluxe car
lotussutol is offline   Reply With Quote
