08-12-2007, 03:22 PM | #1 |
Active Member
4x4 Chassis ID + Value
I am looking at truck to part out.
The body is a 1950 Ford however it looks to be on a GM chassis. It has PS (saginaw box), PB, ( hydroboost), 4 wheel drive with at least a dana front axle, posi rear axle. Come someone tell me where to look to ID the chassis, transfer case. I would guess it is a mid 80's but really have no clue. It drive, 4wd works, brakes work, if the chassis, transfer case and T400 is worth anything let me know. Was Hydroboost a factory installed item? Thanks Bill
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles 18.5" x 31" Hoosier Pro Street Radials ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree |
08-12-2007, 07:09 PM | #2 |
Re: 4x4 Chassis ID + Value
Post some pics and I can give you a time frame of the year if its a 67-72.If its got a turbo 400 it likely isnt a 67-72 frame as there wasnt turbo 400s in the 4wds but it could of always been added.There is a vin on the front of the frame but with pics its easily identified.Also post a pic of the t-case and it can be i.d.'d too
08-12-2007, 08:06 PM | #3 |
08-12-2007, 10:59 PM | #4 |
Nope,only turbo 350s
08-13-2007, 07:51 AM | #5 |
If it really has a turbo 400 and hydroboost, it would most likely be a '77 or up K30. That also means it would have a Dana 60 front axle. Post some pics.
Tim |
08-14-2007, 09:17 PM | #6 |
Active Member
OK here are some pics = the tranny is a turbo 350
Again it does have Hydro boost with front disc brakes PS with a saginaw steering box and a GM tilt steering wheel
08-14-2007, 09:33 PM | #7 |
On the rear shocks,do they both point towards the cab or the passenger side pointing forward and the drivers side pointing to the rear bumper?I see a swaybar,which the 67-72 4wds didnt have.It could have been added but the chassis is possibly a 73-??.The axles are 1/2 ton.12 bolt rear,44 front.
08-14-2007, 09:42 PM | #8 |
Active Member
staggered shocks- drivers side points back, passenger forward
08-15-2007, 12:00 AM | #9 |
Then that would be a 73-78 or so 4wd,assuming the front differential is original.Around 78 or so they went to the Corp. 10 bolt front.
08-15-2007, 01:53 AM | #10 |
can a 73+ sway bar be installed on a 67-72 k series truck? the top spring plate looks like it might work
08-15-2007, 07:52 AM | #11 |
It can be done pretty easily. You have to do some fabbing for the upper mounts.
Tim |
08-15-2007, 08:58 AM | #12 |
Active Member
Ok any idea on what the transfer case is?
What about value for the entire set up rolling with tranny, transfer case, front and rear axles.
08-15-2007, 09:43 AM | #13 |
Thats a NP205 case.
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
08-15-2007, 04:07 PM | #14 |
I would say its worth around 600 figure 300 to 400 for the trans and transfer case and then 150 to 200 for axles if you were to part it out you may be able to get 700 for it but it would take some time.
Earl 68 2500 4x4 GMC Burb |
08-16-2007, 12:28 PM | #15 |
GEARHEAD
73 and up 1/2 tons did not come with a NP205 T case. Are the axles 8 lug or 6? If they are 6 lug, I think there may have been some swaps made. You could get a NP205 and Dana 44 front on 3/4 ton trucks though.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
08-16-2007, 12:38 PM | #16 |
not positive but that t-case looks just like my 203
08-16-2007, 04:03 PM | #17 |
That case is a 205 for sure and its posible that it is out of 1/2 ton just not 73 more like 83 and since its a 400 trans I would say half ton 6.2 diesel truck or burb both came with a 400 trans up to around 84 85 then they went to the 400 with 208 or 241 in the 3/4 and one ton and the 1/2 ton got a 700r4 with a 203. I get them dert cheap around 600 for the hole burb or truck if it doesnt run. Get the BOM number off the front axle and we can look it up.
Earl 68 2500 4x4 GMC Burb Last edited by earl87gta; 08-16-2007 at 04:05 PM. |
08-16-2007, 08:57 PM | #18 | |
K10's never got TH400/205 combos, neither did K20's for that matter...K30 only combo. However, some C10's got the TH400, and quite a few K20s got TH400/208 or 241 combos. Also, the 700r4 never came with a 203 behind it from the factory.
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 |
08-17-2007, 12:44 AM | #19 |
I missed were it went from a 400 to a 350. I had a 82 6.2 diesel k10 and I dont rember it having a 700r4 in it I dont think it had over drive maybe it did its been years ago I know my 86 k20 has 400 and 241 in it. but if his has a 350 no telling what it came out of you can still get the BOM off the axles and look them up and see what they came from.
08-26-2007, 09:27 PM | #20 |
Active Member
OK I did find that tag and confirmed that this is an NP205 Dated in late 1972
So it should be out of a 73 truck The rearend is dated 272 making it an early 72 rearend so it has most likley been swapped in, I am going to pull the covers and confirms insides and gears
08-26-2007, 10:06 PM | #21 |
ive seen a 73 blazer with a th350/ 205 combo but it must have been an early one
