Old 08-13-2007, 10:41 PM   #1
bagged74
its just $$$$$
bagged74's Avatar
ac compressor and tall valve covers
will the stock compressor clear a set of tall valve covers like the ones pictured below?
and can someone post a pic of how the bracket actually mounts?
bagged74 is offline   Reply With Quote
Old 08-14-2007, 01:11 AM   #2
streetstar
streetstar's Avatar
Re: ac compressor and tall valve covers
I started a similar thread inquiring the same thing about Big block brackets. A few board members directed me to Alan Grove components -- he has brackets for small and big blocks (and a bunch of other crap) that works good at very reasonable prices. Sanden makes small AC compressors too, that blend in a little better under a nice truck's hood
But as far as using the stockers- i have no idea -- remove and replace is the only way i know how to wrench (unfortunately)
streetstar is offline   Reply With Quote
Old 08-14-2007, 01:18 AM   #3
bagged74
its just $$$$$
bagged74's Avatar
I guess I'll round up a compressor and see if it'll fit.
Old 08-14-2007, 02:29 AM   #4
Pyrotechnic
Pyrotechnic's Avatar
If it's the huge Harrisson log compressor, it won't work. Not sure about the short/fat compressor in a V-Belt setup though.
Pyrotechnic is offline   Reply With Quote
Old 08-14-2007, 03:04 AM   #5
kevinr1970
I tried to use some not quite so tall covers (but taller than stock) and it wouldn't work.
Maybe with a little more effort than I was willing to give but not just a bolt on deal.
I had the "radial" compressor.
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 08-14-2007, 10:49 AM   #6
swb85
On a budget like Fred Sanford
swb85's Avatar
The stock r4 compressor won't work with those valve covers, the lines on the back of the compressor will hit. I've got "tall" (1/2" taller than stock) vortec valve covers and mine barely fits. Your covers look way taller than mine.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 08-14-2007, 11:30 AM   #7
bagged74
its just $$$$$
bagged74's Avatar
Its looking like a set of aftermarket brackets and a sanden comnpressor are in my future.
Old 08-14-2007, 05:51 PM   #8
piecesparts
Parts and more parts
piecesparts's Avatar
I have the short Harrison compressor on my 84 with all valve covers from Street and Performance. The clearance is no problem on most tall covers, because before the S&P covers, I had aluminum covers from the Chevrolet Performance product line, which are now on my son's truck and he has a short style A/C.
piecesparts is offline   Reply With Quote
