Weapons Of Construction
Best Headers for a Big Block?
I need a new set of headers. Mine have one horked up collector, bent flanges and a lot of rust.
Anybody have good or bad experiences with any on a 402? Mine is BB, TH400, 2WD on a 3/4 ton. I'm interested in some ceramic coated ones, but I don't know where to start. Any mail order house suggestions with part numbers that you know to fit are very welcomed. I need to find some that fit without having to dent them. I also noticed my current ones are very close to the lower A-Arm bracket and would like to avoid that on the new ones. Thanks! ![]()
1971 GMC 2500, 402/TH400 4.10 Daily Driver Lafayette, CO |
So Many Ideas, So Little Money
I have cheap dyno max headers(not ceramic coated) in my 71 LWB 2WD c-10 with 454 and TH350. went in EASY, didn't even pull the spark plugs, jack the front end up and put it on jack stands and they slide down and tip into place
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors 71 C10 with 454 99 S-10 5.1L SBC 700R4 09 Malibu ![]() Marshalltown, Iowa |
I went with the Dynomax 86022 headers for my 402 BB.
They went in real easy and fit perfectly. Ed @ MotherTruckers hooked me up.
Zurbo's Chevy - 1972 Black/White Cheyenne Super. 402 Big Block /THD 400, factory air and tilt. My other Chevy - 1998 Camaro SS |
Senior Moment
![]() Join Date: Mar 2002
What about with AC? Do you use your original brackets? I'm thinking of headers but I want to keep my AC where it is
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
Thanks All!
It looks like I'll be ordering a pair from Ed. Luckily I don't have A/C any more, so I don't have to worry about that.
