Old 09-25-2002, 11:27 PM   #1
Paul Clark
Trim idea (maybe)
72 LWB. (probably doesn't matter)
Lower door trim -
Door panels are removed so I have access to the inside of the door.
Plan on using the clips with bolts/nuts on everything but the front hole. I can tighten them down with a wrench.
Gonna use a push-in clip in the front hole so I don't have to fight putting the nut on the bolt behind the hinge.
Will this work?
Good idea - or not?
Paul Clark is offline   Reply With Quote
