Old 09-26-2002, 01:21 AM   #1
Dropt72Shortbed
Dropt72Shortbed's Avatar
free air bags
air lift is doing a buy 3 get 4 deal on their new gen 2 air bags. im ordering mine tomorrow.
http://forum.sportruck.com/showpost....mode=flat&sb=5
Dropt72Shortbed is offline   Reply With Quote
Old 09-26-2002, 02:01 PM   #2
jay-dawg
chevelito
jay-dawg's Avatar
which ones should I get for the c10 and also for my 4 cyl s10?
jay
New deadline...when my son can drive.
Aloha from Honolulu, HI
jay-dawg is offline   Reply With Quote
Old 09-26-2002, 02:53 PM   #3
Dropt72Shortbed
jay
s10s dont have much space up front. i believe they usually use the firestone 255s which are their 2b6 extended bags. you can fit the bigger 2b7 bags up front and i believe it makes the ride quality better but youll have to hack and trim alot of the coil pocket. out back i think you want to use their sleeve bags, thats waht airride tech includes with their kits.
on your c10 order the big 2b7 for front and 2b6 extended
order the 1/2" ports, chances are youll only be using 1/2" line which only requires 3/8" ports but if you ever want to step up to 5/8" line then you wont have to worry about replacing the bags.
anyways call them up and ask them what they recommend for both, theyll be able to tell you.
Old 09-26-2002, 02:55 PM   #4
Dropt72Shortbed
oh and dont waste your money on buying the extreme bags unless you plan on hopping your truck, running high pressure and nitrogen etc..
