Before and After
rattle can primer
I am just starting on the body work, and I know that bare metal can't be left for too long . I will be on and off this job, and want to know if I spray rattle can primer on the bare metal, (where I am fixing the rust), will it have to be removed and a good primer layed on before paint? Or am I wasting my time with this step?
Not Grandpa's C-20 anymore... 383 Stroker 425HP, 485Ft/Lbs Lowered 3.5" Front / 5" Rear 66,000 miles. Alberta, CANADA |
Gotta Startem Early
The rattle can primer should be removed and resprayed with quality primer. But as a temporary thing, if you are not planning on leaving it like that for like a year, it should work just fiine. Make sure it is completely removed though. Others on this board have used it for this purpose.
67 SWB In Progress, one piece at a time, maybe 3 years I will be finished |
If your options are to rattle can it, then remove later for real primer, or let your freshly fixed metal rust, I don't think it would be considered as "wasting your time".
my 2¢ - t.i.o.l.i. Bowen 1968 K20 fleet 1969 K10 swb fleet 1972 K10 Suburban 1972 C10 lwb step 1992 K1500 'burb 1995 K2500 'burb 1997 C1500 'burb 1999 K1500 2000 K1500 'burb Why do I own so many Suburbans? |
Cantankerous Geezer
Non-epoxy primers offer little protection against rust, especially the rattle cans. If the primer is left uncover for more than a week, depending on your climate, rust will form under the primer. Shoot over the primer with a coat of enamel, it's not that much harder to remove than just the primer.
Fred There is no such thing as too much cam...just not enough engine. ![]() |
